Registered Minimalist
Rocker on 4 and 5 redish and rusty looking
1,2,3 and 6 are normal looking. Rocker 4 and 5 have a rusty appearance.
4 also had one very black and oil covered spark plug. What do you think? ![]() A little background. A 75 911S 2.7 Car has been sitting for 10 years with bad fuel pump and accumulator. Got it running oil pressure reads fine. |
Looks like water got inside the valve cover
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Right, my first thought too. So not oil starvation and overheating right? That would look different?
The valve covers had a thick silicone bead with old gasket. I cleaned up both surfaces and put just the new gasket in and tighten the new hardware down in a star pattern snug. |
non-whiner
That's the intake side. What does the exhaust side look like on those cylinders?
"Too much is just enough." |
also look to see what the lobe surfaces on the cams look like. If they're pitted you may me inadvertently milling metal particles off of the cams/rockers and into the engine. Don't fire this engine up any more if you can ovoid it.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
Schleprock
#4 has a leaky valve guide
Kevin L '86 Carrera "Larry" |
Here is the Exhaust side
Best I can get of the lobes I cant see immediate pitting. I'll check when I do the valve job.
