arbita1's Avatar
Is This Normal on the Case
I noticed this today on the bottom of my case. Is this normal?
And why is there this much oil on my engine. Where is it coming from.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-09-2016, 06:01 PM
E Sully's Avatar
Looks normal. Triangle of death, leaky rocker shafts, valve cover gaskets, oil return tubes seals, head studs, fan blowing air and oil all over the place.
Pick any or all of the above.
Ed
1973.5 T
Old 03-09-2016, 07:01 PM
Air Medal or two
afterburn 549's Avatar
Looks like a job for- RSRS "O" rings on the rocker shafts!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-12-2016, 07:52 PM
Are you talking about the file/grinding marks at the seam? That's just where they cleaned up the casting flash at the factory.
Old 03-13-2016, 06:36 AM
Air Medal or two
You should have a groove all around each end of the rocker shaft(s)
Old 03-13-2016, 07:24 AM
arbita1's Avatar
Yes. Thanks.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-13-2016, 07:45 AM
non-whiner
mreid's Avatar
Normal, now get to work!
"Too much is just enough."
Old 03-13-2016, 07:51 AM
