| (man/dude) | Quote:
 Certainly seems like the 42mm HE's support a good HP number!
				__________________ Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 | ||
|  03-07-2019, 07:13 AM |
| Registered Join Date: Sep 2004 Location: Woking, McLaren-land
			Re outlets, yes correct, one flange wasn’t flush with the muffler inlet.
				__________________ Shirish 1987 Carrera, Granite Green | ||
|  03-07-2019, 09:26 AM |
| Registered Join Date: Apr 2008 Location: Houston, TX
			Can you share some info on the velocity stacks air filter setup? Is that available off the shelf or custom made? And when you used the 964 plenum, where did you source the air filter setup? Gamroth? | ||
|  03-09-2019, 06:54 AM |
54.5-55mm OD - slight variation along the length, but similar side to side
|  03-09-2019, 12:14 PM |
				 | Quote:
 Rothsport wouldn’t sell me the filter setup on its own, so we had one made. The filter is available off the shelf. Mine is available for sale - plenum, resonance tube, vacuum activator, filter and the legs that join the plenum to the flange with the heads. You’d need to sort the 2 bolt adaptors for the legs to mate with - I think Jenvey may do them, or turbokraft.
|  03-09-2019, 12:27 PM |
| (man/dude) | Quote:
 The Dansk stainless muffler bolted to them has inlet tubes that are exactly 50mm OD. Would be interesting if the eisenmann muffler has matching inlet diameters.
|  03-12-2019, 04:54 AM |
| Registered Join Date: Jul 2005 Location: Atlanta
			Great set up! Do you recall how much ignition timing in total is being used at WOT?
				__________________ No physical quantity completely explains its own existence | ||
|  03-12-2019, 06:38 AM |
| (man/dude) | Quote:
 Thanks and all the best!
|  03-13-2019, 07:11 AM |
				 | Quote:
|  03-13-2019, 07:30 AM |
Will check
|  03-13-2019, 07:31 AM |
Qualification - this is the right part for SSI muffler compatible Eisenmann.  The alternative is the 3.2 setup, which mandates the Eisenmann muffler
|  03-13-2019, 09:52 AM |
| (man/dude) |
Nope that's perfect, thanks!!! I understand the difference with the G series model. Pics on their website aren't 100% representative. The pics of yours and the pic of the part number are especially helpful, thanks again.
|  03-13-2019, 06:47 PM |
			Couple of v quick acceleration vids, I love the way it sounds: https://youtu.be/EKQ0eRZnCAM https://youtu.be/50EtM1ElpQg
|  03-15-2019, 04:24 PM |
| Registered Join Date: Oct 2016 Location: PNW
				 | Quote:
				__________________ _______________________________ 1982 911 SC 240,000mi and counting | ||
|  03-18-2019, 05:10 PM |
| Registered Join Date: Nov 2017 Location: Houston, TX
			I see that ATpower makes 911 itb's in 42 or 45mm. Which did you use?  Did it match up well to the plastic plenum? Dan Sent from my Nokia 7.1 using Tapatalk | ||
|  03-21-2019, 06:34 PM |
				 | Quote:
 The 42mm taper to 40mm - I think better sized for a 3.0 We chopped the plenum legs and added silicone joiners
|  03-21-2019, 11:28 PM |
| Registered Join Date: Feb 2012
			Great   Sent from my iPhone using Tapatalk | ||
|  05-24-2019, 12:28 PM |
