arbita1's Avatar
I ordered the better tip that heats faster. I'll have that on Wednesday and we'll see what happens.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-04-2016, 02:08 PM
theiceman's Avatar
Originally Posted by boyt911sc View Post
Matt,
I am doing my 15th engine rebuild and had encountered stubborn cylinder head studs maybe 3 times only. I usually do it without heat and could get them out around 30 mins. But with a stubborn stud, additional heat is needed. Apply heat for 10 to 15 mins. on the spigot using a MAP to melt the bond between the stud and the crankcase. If my memory serves me right, I have removed more than 150 Dilavars head studs. About 4 dozens or so Dilavars studs are saved in my garage.
Using a Snap-ON stud remover and a strong impact wrench are my primary tools which I learned from Tom Butler.
Tony
This . I had one I had to heat for 15 minutes with my map gas . I gave up on pipe wrench and got a set of vice grips on the stud. the stud actually began to twist at one point but she finally let go and was miserable all the way till the end . What a satisfying feeling getting that last bugger out.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-05-2016, 09:52 AM
I slid a nut over the stud till about 2 inches above the case and mig welded it from both sides. heated the case 15 minutes with the torch. (use plain steel nut). Put a ring spanner and an 1.5 foot breaker bar on it. On the ones broken off just above the case I put a washer onto it to protect the case and mig welded also a steel nut on it. Heated the case again for 15 min. All 24 studs came out including the 7 broken dilivar studs. When I delivered my parts to the machine shop the owner said to me " We put the case in an oven and take them out for free as we hate solving client mishaps" Still very satisfying to have done it myself.
Old 04-05-2016, 11:45 AM
theiceman's Avatar
not a better feeling when you are sitting back staring at it after with a beer in hand !!!
Old 04-05-2016, 04:41 PM
You need to add thread penetrant into the above equation (same as for removing exhaust system fasteners) It helps dissolve any metal corrosion and reduces friction between the threads. I use Kroil, but other brands are better than nada.
Sherwood
Old 04-07-2016, 12:30 PM
arbita1's Avatar
Sherwood
I've been hitting it with PB Blaster.
Yesterday I received the recommended torch for my map gas canister. The flame is much bigger than my other torch. So hopefully I'll get to try it tonight.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-07-2016, 01:21 PM
arbita1's Avatar
Thanks guys! That worked!!
On to the next step!
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-07-2016, 05:38 PM
For how long did you need to heat?
'90C4
Old 04-08-2016, 06:13 AM
theiceman's Avatar
i bet a while, that bugger started to twist, i had on of those too , it seems every engine gets one ..
at the factory .... " remember guys, put that super epoxy on one stud on every engine to discourage those DIY guys "
lol
Old 04-08-2016, 06:56 AM
arbita1's Avatar
Maybe about 5-8 minutes.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-08-2016, 07:00 AM
arbita1's Avatar
Originally Posted by boosted79 View Post
That's the torch you need. Just keep the heat on it until it lets go.
Thanks for recommending this torch. It's my new favorite tool. I was having trouble removing the pulley bolt. My 1/2" electric dewalt wasn't breaking it free. And that thing is powerful.
I soaked in PB blaster overnight. Hit it with the torch today for a few minutes. And I spun it right off.
Ready to split the case.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-08-2016, 02:50 PM
Glad it worked out for you. It's great for lighting cigars too!
Old 04-08-2016, 03:26 PM
arbita1's Avatar
Whoa. Cool.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-08-2016, 05:17 PM
