Good info sir. I just looked up the part number for the exhaust stud and it is the same as the oil pump stud. And lists the same size. At least I know I ordered the correct one. Thanks. Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
Disassembly Done ... Time To Rebuild 3.0
Back from vacation and I'm ready to go. I think I have most items I need to keep me going for a while. Got my replacement stud while I was away.
Also got this cool package. ![]() JE pistons from ebs. And they are domed for cis. See... ![]() Also got these. ![]() Replated in nikasil by ebs. Also got these polished and rebushed from Craig a while back. ![]() Cams are with John for a regrind and head are at the local machine shop that does them for some of the indies in my area. Now just need some time to work! Sent from my iPhone using Tapatalk
wow, cylinders look new!
Yes. Not sure how they did that. Sent from my iPhone using Tapatalk
That Guy
Long time no see Matt! Looking good, ill be sending my cylinders to EBS next month for the 3.4L treatment.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
That car you have is perfect as is. Guess you can't leave well enough alone. Very happy with EBS. Sent from my iPhone using Tapatalk
That Guy
Valve guides are toast (1qt>600mi) and i dont trust the rebuild that the previous owner had done. Splitting the case and 'while your in there' decided to just do the 3.4L.. cost wasnt really much more expensive if i have to replace the 3.2L p&c's which is probably prudent considering the mileage...lol. Atleast i'm not doing an LS swap
Do I have to use loctite for the oil pump stud into the case?
Ugh. Getting my hardware ready and organized for case sealing and I'm realizing I'm somehow missing a cap nut.
![]() Sent from my iPhone using Tapatalk
Counterclockwise?
Are you sure it's not the regular nut you are missing? I looked for 1/2 hr before realizing this lol.
My engine guy did not use lock tight.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
No. I'm missing one cap nut. I'm trying to remember If I damaged it when removing. I ordered a new one today. Kind of annoying ordering a nut that costs $15. Sent from my iPhone using Tapatalk
He emailed me a few weeks ago to let me know they would be done soon. Maybe he went on vacation. Everyone is away this time Of year. I'm going to reach out to him this week.
He actually emailed me back the next day. Try emailing him again.
Case is sealed together. I hope it doesn't leak. I felt like I wasn't putting enough 3 bond on but I kept remembering that everyone says a thin coat. Wasn't difficult except for the time limit factor. My heart was racing and i was sweating.
![]() ![]() Sent from my iPhone using Tapatalk
Great thread, I will be right behind you, maybe another month or so.
best of luck |
Good progress today. Finished Section 3 in Wayne's book!
![]() ![]() On to section 4 ![]() Sent from my iPhone using Tapatalk
Today I installed the rings on all the new JE pistons. JE recommends the ring gaps in the 10 and 2 position where as Wayne's book recommends 9 and 3. JE says not to orient in line with the wrist pin. So I think I'm going to to follow that.
Thread Tools | |
Rate This Thread | |
