Fuel injectors installed. Engine is done!!!
Ready to go back in. It's been almost one year to the day I dropped it. ![]() Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
Dougherty?? |
Subscribed!!
Just started taking apart my 3.0. Talked to John D couple days ago. seems like a good guy. Probably be sending my cams off soon |
Disassembly Done ... Time To Rebuild 3.0
Finally back in. It's been almost exactly a year since I dropped it. Still have to finish connecting everything but at least it's back in!
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 02-09-2017 at 02:53 PM.. |
Going to use this for my break-in oil.
UnRegistered User
Startup this weekend?
Hope it goes well. Turning the key on any overhaul is always a big "pucker" moment....
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
No. I still have to connect all the stuff underneath. Cv joints, etc. Plus too much snow here to do the initial drives. Probably not going to start for a few more weeks. Yes. I am very very nervous about the first start. My biggest worry is oil leaking out. ![]() Sent from my iPhone using Tapatalk
Member 911 Anonymous
Don't sweat it OP, just do the proper pre-break in procedures to insure all is moving freely then go for it.
Break a leg brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Finally finished the remaining misc stuff. Put the tires on and took it off the jack stands.
I put the oil in and did the pressure build up today. The oil light went out within a few seconds on first try. Did it a second time per the book and it went out quickly again. No oil spray or leaks. So I'm taking this as a good sign thus far. I'm dying to start it but I don't have time to change the oil today after I do. So I have to wait. Sent from my iPhone using Tapatalk
It's alive!!
I'm trying to attach a video but it's not working. It took a bit of convincing to start up. But it finally did. I ran the 20 minute break in. No leaks. It smoked like crazy for about 3 or 4 minutes and then it stopped smoking which I took as a good sign. Changed the oil after 20 mins. I really didn't see all the metallic flakes that the booked talked about. I set the idle and timing. Did two of the four initial drives. 5 mile and 10 mile. Seems to be good so far. I think I need to check my co setting. The idle does not really want to come down. I was hoping to feel a quicker engine since I fixed a few cis and distributor issues. And also changed to the dc15 cam. As well as a slight bump in compression. But it feels basically the same as I remember it. Maybe after I check co setting I'll get better power. I didn't see leaks after the drives but the ssi's were smoking. I think it may be the residual oil on them as my engine had a lot of leaks and they were covered in oil. I tried to clean them off prior to reinstall but maybe I didn't get it all. Not sure what else it could be. Right now I'm just really happy to be driving my car after a year of rebuilding. I still can't believe I've done this myself. It's a great feeling.
Under the radar
My first impression when driving with my new motor was similar to yours. My new motor sounded the same as my old one. During normal driving, it even felt the same. I have spent the last two weeks fiddling with the carbs and timing. It still is eerily the same as my old motor UNTIL I get past 2/3rds throttle, then all hell brakes loose!
Do get it fine tuned, then you will probably be pleased.
Looking forward to hearing more about it.
1994 968CS 1977 911S 1969 MGB GT 1958 Norton Dominator |
Thank you. Good luck on your rebuild. The start of the engine is pretty nerve racking. However I did find that having to crank the starter to build oil pressure gives some piece of mind that it's going to be ok.
I did some more break in driving today. Put another 25 miles on. Need to do another 45 miles before I change the oil again. After coming home I adjusted the timing again. And set the CO. It was pretty lean. Went out for another test drive... Never mind what i said before about feeling the same. This is a totally new car. Power is definitely improved. Acceleration is great in all rpm ranges. It's amazing. I still have some high idle issues I need to address. But i will finish the initial break in drives before I dive into that. Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 02-25-2017 at 12:05 PM.. |
Finished the last of my initial drives. Car feels great. Love the power on the new cams. Feel like I have much more power and acceleration than before. Dumped the oil after the drive and will refill with Kendal gt-1 competition for the next 500 miles. No smoke or leaks as of yet. So I am happy. Still can't believe I rebuilt this thing myself.
Congratulations on your rebuild. I wish you tons of miles with no issues at all.
'71 914-6 #0372 '17 Macan GTS |
