wprater's Avatar
Can't compress rebuilt tensioners
I rebuilt my 930 style hydraulic tensioners, but they are so firm I'm not able to compress them to install. Is there some trick, or did I fill them with too much oil?
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 04-19-2016, 05:46 PM
Under the radar
Trackrash's Avatar
Use a vice to compress them. Go slowly. You should not be able to compress them by hand.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-19-2016, 06:01 PM
wprater's Avatar
Neglected to mention that I was using a vice.
"slowly" was the key I was looking for (thanks!) I was able to finally get them compressed, but they'll spring right back up after you releas the vice. I was going to test fit them, but I worry I won't be able to get them out either.
Is the solution to vice them slowly and somehow shove the vice in under the idler arm??
1990 911 Carrera 2
Old 04-19-2016, 06:26 PM
abit off center
cgarr's Avatar
Isn't there a hole for a grenade pin to hole them compressed?
Craig
G2Performance
Old 04-19-2016, 07:00 PM
wprater's Avatar
these are not the pressure fed Carrera tensioners. But the turbo style hydraulic ones. They dont have the pin :|
1990 911 Carrera 2
Old 04-19-2016, 07:58 PM
74 911 Targa
pond scraper's Avatar
This is what worked for me. Not saying its right, just what worked.
You need a bar clamp, vice grips and 2 L brackets with part of one side cut off
Make sure the tensioner pin is not sitting in a screw hole of the L bracket, flat part of bracket only, the side that was cut off. Compress everything together, lock down vice grips, position tensioner in engine, unlock vice grips and gently remove brackets. The (gently remove brackets) part was the hardest as the tensioners are supplying significant force.
I am sure there are better ways but in a pinch...
Old 04-19-2016, 08:39 PM
Bend up a tool from a strip of steel that looks like a rectangle missing one long side. Put the tensioner in the vise with 1/2 the shaft above the vise and slip the tool over the tensioner.
206 637 4071
Old 04-20-2016, 04:14 AM
mskala's Avatar
Yes this is what I always did.
Mark S.
'70 914-6
Old 04-20-2016, 07:20 AM
wprater's Avatar
thanks for the replies. sounds like everyone is on the same page.
I don't quite understand John's advice of having the shaft half out of the vice.. ?
Old 04-20-2016, 09:47 AM
TibetanT's Avatar
What John is saying is: "put the tensioner in the vise and allow the top of the tensioner (rod-end) to be above the top of the vise by a little bit."
That way you have some of the tensioner (rod) available so you can slip the tensioner tool over it to hold it in place. This allows you the ability to walk over to you car/engine and place the tensioner into its "home" within the Chain Housing and then, remove the piece of steel so the tensioner expands.
Hope this helps and good luck.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-20-2016, 11:26 AM
wprater's Avatar
Thanks, I get the concept. I just don't see how you can have half a rod extruding past a vice?! Maybe half of it's width could be sticking out?
All this is helpful, thank you all!
1990 911 Carrera 2
Old 04-20-2016, 11:34 AM
Tensioner laid flat in the vise, each jaw grabbing 1/2 the diameter of the shaft and the body. 1/2 the side of the shaft sticks up from the top of the vise so you can slip the retainer tool over it without opening the vise. Then open the vise.
206 637 4071
Old 04-20-2016, 11:41 AM
Home made tool.
206 637 4071
Old 04-20-2016, 11:45 AM
Emo993's Avatar
Very nice John, thanks for a great explanation. Mark
Old 04-20-2016, 03:32 PM
Tensioner compressor
Use an appropriately sized hose clamp. The clamp will compress the tensioner, hold it compressed, and allow installation in the compressed state. Once installed, the hose clamp can be loosened and then slipped out of the tensioner housing. Voilą
Old 04-21-2016, 08:32 AM
Ok so dumb question as I haven't rebuilt a 911 engine in about 4 or 5 years but with the 930 tensioners or equal to . are people using stops as a failsafe now?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-22-2016, 10:20 AM
al lkosmal's Avatar
clamp
I use John's method for the mechanical tensioners................but I re-purposed a very special tool.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-22-2016, 06:56 PM
