Slippery Slope Expert
Steam Driver's Avatar
Cam Timing Question
Why is there a special tool for tensioning the timing chains when setting timing? Why not just use the tensioner itself? It seems to me that with the special tools (or Vise Grips) there could be a real danger of over tensioning the chains and causing some serious problems down the road.
Old 04-26-2016, 06:03 AM
Most cams have a window of settings. I tend to set high to account for thermal expansion while running. I just install tensioner, lift the idler so the tensioner compensates and set the cam. Never a problem.
Bruce
Old 04-26-2016, 07:40 AM
That was my thought as well. If one has the tensioners on hand why use a special tool? I see no point in tensioning the system more than the tension it's designed to run under all the time.
Old 04-26-2016, 09:53 AM
Under the radar
Trackrash's Avatar
I think the issue may be the fact that the tensioner can compress some if there is tension placed on the chain. I use a small C-clamp just to make sure the chain stays tight.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-26-2016, 10:08 AM
Alan L's Avatar
I think the tensioner on one side gets in the way of doing the cam bolt?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-26-2016, 01:47 PM
Bolt style cams work with the tensioners in place. The old style cams with the big nut need the tool on the left side.
206 637 4071
Old 04-27-2016, 06:46 AM
