Perpetual Reassembler
2jmotorsports's Avatar
Reuse Crank Circlips?
Can the circlip that holds the distributor drive gear on a 3.0L crank be reused?
I am about to send my crank out to a machine shop to be checked, reconditioned, and have the gears replaced. Not knowing if the new distributor drive gear will be the same thickness as the current one I have ordered a set of new circlips, one of each size (2.1mm-2.4mm) so the machine shop can install the appropriate one.
That said Im having trouble locating a 2.1mm circlip and I may have to reuse the existing one if the current one on the crank is a 2.1.
Thanks in advance.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 05-31-2016, 08:58 AM
KTL KTL is online now
Schleprock
KTL's Avatar
These are quite thick as far as circlips go. So they hold their "spring" effect pretty good. That said, i've seen some that come off with a bit of difficulty and they don't spring back to their original shape. I'd have the new circlips handy just to use as a gauge for shape and then you can decide if the old one can be reused.
Kevin L
'86 Carrera "Larry"
Old 05-31-2016, 11:05 AM
I have new clips to compare to the old one so I will go that route. Thanks for the feedback!
Old 06-02-2016, 04:22 PM
