It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Talking Compression and leak down numbers - look good?
Hello all, I just wanted to give an update on my rebuild that I was fortunate enough to have had this board to help me through. I got my compression and leak down test results back and they look pretty good to me. Do these numbers look good to you?
Compression and leak down test results.
Compression
3. 155 psi 6. 160 psi
2. 160 psi 5. 150 psi
1. 160 psi 4. 160 psi
Leak down
3. 0.0% 6. 1.0%
2. 2.5% 5. 1.0%
1. 2.0% 4. 1.0%
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 05-28-2016, 10:35 AM
I Wonder
mgro1959's Avatar
Readings like that for leakdown dont get any better. Are you sure #3 isn't seized. Ha Ha. Thanks Rob
Old 05-28-2016, 10:47 AM
It's a trap...
I'm pretty pleased. I would not even have began to think about doing the rebuild myself without this board and Wayne's book.
Old 05-28-2016, 06:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Any numbers prior to?
Heck under 10% of each other is pretty damn good ��
'85 Carrera Targa
PCA/POC
Old 05-28-2016, 07:46 PM
dmart2rp
Did you rebuild using Alusil cylinders?
Old 05-30-2016, 09:10 AM
Never seen 0 leakdown.
206 637 4071
Old 05-31-2016, 05:24 AM
Check calibration of leakdown tester gauges. In any event they are great but 0 is impossible.
Old 05-31-2016, 06:03 AM
Chain fence eating turbo
My thoughts too.
I built 100's of bearing housings for jet engines that used a piston ring with an overlapping gap like TotalSeal rings. Never had one show zero
Old 05-31-2016, 06:43 AM
Yes, the gauges have to be calibrated to read exactly the same for a given test psig to give an accurate leakdown %.
Old 05-31-2016, 07:24 AM
DRACO A5OG's Avatar
Maybe he used #3 as the base line??? 10-15% then the rest was under 3% of each other, which is amazing
'85 Carrera Targa
PCA/POC
Old 05-31-2016, 12:43 PM
It's a trap...
I'll call the shop that did these. Should I be suspect of the other number?
Old 06-02-2016, 06:40 AM
DRACO A5OG's Avatar
You can rent for free a Compression tester from your FLAPS and verify for yourself, just remember to pull the DME relay or pull Fuel Pump Fuse.
I bet those leak down numbers are the percentage of difference between them and he used #3 as a base line.
'85 Carrera Targa
PCA/POC
Old 06-02-2016, 10:56 AM
