2.7l head used on a 2.4l engine????
Can I use a 2.7l head casting number 911.104.342.2R on a 2.4l engine with heads with casting number 911.104.302.0R. ? The 2.7 head seems to measure the same. I have one bad cylinder on my race engine. This is a turbo charge engine with enlarged ports.
Thanks Scott |
I think-you can and will
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
The 2.7 outer bevel in the chamber makes the sealing surface almost nil. That's the area toward the inside of the sealing ring on the cylinder. 2.4 on a 2.7 ok, but not VV.
