arbita1's Avatar
Gasket Stuck On Case
How do you remove the old paper gasket when it is stuck on the case. It's the gasket for the chain housing where it meets the case. I had the case hot tanked but that didn't get it off. Yesterday I was trying brake cleaner and very carefully removing with a razor blade. I got some off but I don't want to risk scratching the case.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-02-2016, 04:58 AM
Usually around the stud, I would pull the stud if I needed to get the gasket off.
When installing the gasket, I put 574 on the bottom 2 inches where it might be immersed in oil
Keeping gasket removal problems to a minimum in the future.
Bruce
Old 07-02-2016, 05:57 AM
A single-edge razor blade and a lot of patience.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-02-2016, 09:28 AM
gearhead
3m makes an adhesive remover you can get at a hardware store. I apply that, let sit 10-15 minutes and turn razor blade. Makes a huge difference in effort.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-02-2016, 11:12 AM
gearhead
And just 574 with no gasket when you reseal it.
1974 914 Bumble Bee
2009 Outback XT
U mighy want to use a plastic rotary disc with brissles,with a right angle if u can get it in there
Sent from my SM-N910T using Tapatalk
Old 07-02-2016, 11:38 AM
Old 07-02-2016, 11:39 AM
