Under the radar
Cam choice oppinions?
Hello, I'm building a motor based on an 3,0 SC motor. And I would like some expert opinions on my cam choices. I know this has been discussed, but would still like to hear experiences and recommendations from you all.
Motor specs: 3,0L Heads, '78 SC 39mm intake ports Ignition, Single plug, re-curved SC distributor Pistons, JE 9.5 to 1 ARP rod bolts CR, 9,7 to 1 Carbs, 40mm Webers Exhaust, '71 stock w/sport muffler Transmission, '72 915, stock gears Car, 71 911, 2300 lbs, with driver Use, 75% AutoX, 20% DE 91 octane gas I am after a broad flat torque curve. Not necessarily the ultimate in high end HP. My normal shift point would be 6500RPM, but would want to be able to go to ~7200RPM to save a shift. I am thinking something along the lines of a DC 35, DC 40, or DC 43. Thanks,
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 06-20-2016 at 01:57 PM.. |
Give DRC A Call
Gordon,
Give John a call - I had similar goals and a similar build. He recommended the GT-2 102 cam profile. Couldn't be happier, torque comes on at a much lower RPM range as compared to stock (~185 ft lb @ 3,500 RPM equals neck snapping acceleration). Dyno Results - Gordo's 3.2L Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Under the radar
I was just re-reading your post. It is exactly what I am looking for. I see the GT2 turbo on his site, is that the one?
I have sent Dougtery.com two requests for info, but have not heard back. Thus my post. I guess my next step is to get on the phone if he doesn't chime in.
Schleprock
He's camgrinder here on the forums if you want to send him a private message.
Kevin L '86 Carrera "Larry" |
Puny Bird
Web 120/104 would also be a good choice. Hot street and club racing, good idle and torque.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 06-21-2016 at 11:20 AM.. |
Schleprock
I was going to suggest those too. I have them in my racecar's engine and so did a friend in his 3.3L short stroke racecar engine.
Under the radar
What springs, retainers, rockers are you using and what is your red line? Thanks,
Schleprock
I have EBS Racing's springs and Ti retainers and so did the 3.3L Original rockers refurbished with cgarr's low friction bushings. Redline is 7500. Both cars had Weber 46. Mine was a 3.2 short stroke
Under the radar
What is your maintenance schedule for your TI retainers? Do you ever replace them?
Schleprock
Not sure what a projected time-out is for the springs and retainers. My engine build is rather mild, so I planned on 120+ hours of sustained track driving.
Henry @ Supertec or chris_seven @ Fenn Lane would have a better answer than me!
