hipdoc's Avatar
911E case
I just found this on my 1973 911E case. Any recommendations if this is repairable and who is the best to do it.
Old 07-05-2016, 08:55 PM
safe's Avatar
Doesn't look critical, I wouldn't do anything.
Magnus
Old 07-06-2016, 01:05 AM
Straight shooter
Lapkritis's Avatar
Might treat with grease/oil to stop corrosion. We spend a lot of time stopping the leaks for aesthetics and achieve lowering their natural immunity to corrosion.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-06-2016, 06:14 AM
tharbert's Avatar
Critical, no...but it certainly could become so down the line. I'd give a good cleaning with white spirits to drive out any moisture, buff it down with a non-ferrous wheel and give it a good soaking with something like Meguiar's. It will do nothing but get worse if you do, well, nothing.
Don't use ferrous based wheels or acid to clean.
I believe PAG suggests protecting Mag surfaces where the protective barrier is degraded with Tectyl. You could also look at re-passivating the surface with chomic acid but I don't know if that's a good idea anywhere where on a joint.
Apparently there are all types of Tecyl. Here are a couple from the Valvoline site that may apply:
Tectyl ML Greenline - Aftermarket - Valvoline
Tectyl Glashelder/Klar Spray - Aftermarket - Valvoline
Tectyl Multipurpose Clear - Aftermarket - Valvoline
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 07-06-2016, 07:00 AM
