Transmission cleaning...
I am doing my research (using the search functions) but wanted to also solicit advice directly as I search previous posts.
What have others done to clean the transmission (915) case before a tear down?
What is a good cleaner for brightening the surface after a good power wash and scrub with simple green?
Any concerns with surface oxidation etc. after cleaning?
Thanks in advance for sharing your experience...
Old 08-11-2015, 05:15 PM
E Sully's Avatar
I;ve been considering trying this.
Extreme Simple Green® Aircraft & Precision Cleaner
Ed
1973.5 T
Old 08-12-2015, 05:20 AM
304065's Avatar
search here for Grady Clay and Tectyl.
Bottom line is that the trans case, after being thoroughly cleaned, should be coated with a petroleum product to keep it from oxidizing.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-12-2015, 06:30 AM
Chain fence eating turbo
I bought STP Ooomph:
STP® Multi-Purpose Cleaner | Oomph!® Cleaner and Car Degreaser
Whipped decades of grease's arse! Very impressed.
Has a mild acid IIRC, so the case looks brighter too.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-12-2015, 07:36 AM
Kartoffelkopf
Spenny_b's Avatar
Have a search through my build thread (below), towards the last 4-5 pages iirc I went and cleaned my transmission again after it stood for a few years. Use AluBright - not sure if its available over there...then used Dinitrol clear wax to protect it (I painted it on by hand rather than using the Schutz gun to apply it)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 08-12-2015, 09:19 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The aluminum cases do OK w/out any protectant if its a car that just sees occasional use in nice weather. If its a car that gets driven rain or shine or snow, i'd put a protectant on it. Especially if you're in a region with salty roads.
I would clean the case with a good degreaser like Simple Green or Oil Eater and use pressure washer. To really brighten it up, I recommend you soda blast the case sections. Even with the pressure washer, there's going to be some areas that you can't get clean and you need some abrasive help that the soda blasting will take care of. The diff housing side cover is typically the crappiest looking part of the trans, due to the deep nooks in the cover along the reinforcing ribs.
Kevin L
'86 Carrera "Larry"
Old 08-12-2015, 09:33 AM
Project Addicted
I tried the simple green and pressure washer route on my 901 trans and was really disappointed. I then grabbed the Sonax wheel cleaner, let it soak and then blasted again with the pressure washer. The pictures tell the story.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 08-13-2015, 09:08 AM
johnman001's Avatar
for my $0.02, I use WD40, a brass bristle brush, and lots of paper towels. The WD40 dissolves lots of goo and the brass brush doesn't scratch up the outside of the trans. Your mileage may vary.
If it's apart, I put the whole case in my parts washer. My solvent is safe for aluminum or magnesium.
Dawn will also work, but takes more scrubbing.
Once clean and dry, I usually spray them off with something like Gibbs brand oil to keep them from oxidizing too quickly and it keeps stuff from sticking to them.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 08-13-2015, 10:01 AM
Great responses - thanks for sharing your experience & ideas - keep them coming.
I read about Gibbs oil (I think) used on cleaned up fans as well. What is Gibbs oils and where do you get it. What makes it different from 20 et or extra virgin?
I am always learning on this site!
Old 08-14-2015, 06:15 PM
That was supposed to be 20 weight (as in oil...)
Old 08-14-2015, 06:16 PM
Dave Kost's Avatar
I did the WD-40 and brushes, it works but alot of work. I tried the Citrol, took the tranny to a quarter car wash. Three soakings with the Citrol and high pressure spray and all done.
I got the Citrol from a local Napa store.
Dave K
Old 08-14-2015, 08:49 PM
Kartoffelkopf
Spenny_b's Avatar
Good shout for WD-40 - I didn't think to try it for the transmission case but am always surprised how good it is with cleaning other parts of the car
Old 08-15-2015, 03:15 AM
michael lang's Avatar
I went with plain old mineral spirits and a brass brush. Spent a couple of hours with it. This is what I started with:
And this is what I ended up with:
Time well spent in my opinion. Good luck whichever way you decide to go.
Mike
'89 CARRERA
#402
Old 08-19-2015, 02:17 PM
About pressure washing, can you just start spraying the transmission or do certain areas need to be covered or blocked off?
Old 08-21-2015, 08:10 AM
I have done several with Oven cleaner, I let me transmission sit in the sun for a while to warm it up and sprayed lots of oven cleaner then with a wire brush scrubbed heavy build up areas then pressure washed it off. Overall, the first wash removed almost all of the build up. The second wash and scrub cleaned it all up nicely.
Oh, I did use foil tape to cover the top vent opening, this is the only area I covered up.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 08-21-2015, 12:17 PM
db9146's Avatar
If you are cleaning a trans with a magnesium case, you will want to protect the raw magnesium from oxidation (ever seen raw aluminum left outside? magnesium is worse).
There are some references to a product call Tectyl but I uncovered a newer, seemingly safer solution for protecting the raw magnesium called Prekote by Pantheon (PreKote Surface Pretreatment - Pantheon Enterprises). It is used to seal the raw mag before painting and seems like a simple process. I found it in a spray bottle here (Pantheon PreKote 065-1002 Surface Pretreatment - Quart at SkyGeek.com).
Old 07-18-2016, 11:35 AM
toddu's Avatar
You need to be careful where you spray. You also MUST block the vent port on the top side.
Todd
'81 SC
Old 07-18-2016, 02:14 PM
Puny Bird
Mark Henry's Avatar
Todd
I agree.
Personally I wouldn't pressure wash a case unless it's coming apart the next day. You can blast right past the seals.
I also wrap the stubs, input shaft and shift rod tight with old rags.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 07-18-2016, 07:40 PM
