Originally Posted by toddu View Post
What causes pitting on a cam like that?
Todd
Too little ZDDB (Zinc) in modern oils from what I've read, you can buy oil from a specialist supplier with a higher ZDDB content
Old 07-30-2016, 10:08 AM
Originally Posted by Sboxin View Post
I would open up the case and rebuild the bottom end - - since you are already this far along.
Because of the damaged cams, you may find damaged bearings also.
You have already done the hard work on this engine . . .
We found this in our engine . . . #5 rod bearing damage - either bad/low oil or run too hot . . .
And, the intermediate shaft bearings needed replacement . . . so rods, crank, and flywheel off to machine shop for refurbish and balancing - well worth the low cost . . .
Regards,
Well I took your advice, and decided to split the case.
Again, being new at this, I wasn't sure what to expect.. I think my main bearings looked mostly fine.
I decided to remove the rods and found very fine scratches.. my fingernail did not get caught in the scratch... but all will be replaced regardless.
Old 07-31-2016, 02:19 AM
first split
Old 07-31-2016, 02:20 AM
crank
There is 1 tiny scratch on one of the crank bearing surfaces.. I can get my nail to catch in it.. Shold I get the crank polished?
Inside the case was very clean.. only debris was from me removing the head studs (locite bits) and splitting the case.. (a bit of gasket cement flaked off)
Old 07-31-2016, 02:23 AM
Old 07-31-2016, 02:24 AM
Old 07-31-2016, 02:25 AM
Case got a clean
Old 07-31-2016, 02:26 AM
Old 07-31-2016, 02:27 AM
Old 07-31-2016, 02:28 AM
I see a couple of issues here. The scratches look like debris contamination to me, while one bearing shell shows shows some wear that could have been caused by a breakdown in the oil film. I've seen that in engines that were lugged excessively, but I suppose that there are other hard use conditions that can cause this.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 07-31-2016, 07:49 AM
Sboxin's Avatar
" Shold I get the crank polished? "
Mike,
Good work on your engine !
Yes, while the crank and rods are out you should find the best machine shop in town and have them refurbish the crank (polish) and the rods - and balance the whole rotating mass . . . crank, rods, and flywheel. Porsche does excellent work on the original parts and very little improvement may be seen in a second balancing job - but at least you know it will be close to perfect when you put it back together.
A question: what oil have you been using ??
We use Amsoil Race oil 15-50 that has a high zinc content - but it is a race engine with no Cats to worry about. And, we get an oil analysis done with every oil change . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 07-31-2016, 08:52 AM
Mike,
Regards,
Roy
I have only had the car a year, and travelled 2000 kilometres in that time.. I have been using a locally produced oil... HPR 30 20W-60 (Mineral)
It claims to have zinc 1600 ppm.
Before me, well, I just don't know that they used and hence why I am doing this. Pretty sure the car was rarely used though.
Old 07-31-2016, 11:19 AM
Sboxin's Avatar
Originally Posted by mikedsilva View Post
Roy
That Penrite oil looks like a very good oil . . . cam damage was probably done before you got the car anyway . . .
Good luck with the rebuild,
Regards,
Old 08-01-2016, 09:41 AM
Update
My cams and followers have been sent to John Dougherty in the USA for regrinding.. upon consulting one of the more reputable Porsche shops here, they claimed that there wasn't anyone in Aus doing a good enough job and that it wasn't worth risking.
Still not sure on changing the profile though... at this stage I have told John to keep it stock...
Old 08-11-2016, 03:06 PM
