Connecting rod bolts torque
Hello all,
I have a 1978 911 sc I'm ready to torque my connecting rod nuts to the crank shaft but I'm not sure if it's: 1. Torque bolts to 14.7 lbs 2. 90 degree Or 1. Torque bolts to 14.7 lbs 2. 90 degree 3. Another 90 degree Thank you |
Member 911 Anonymous
Per Porsche Tech Manual for a 3.2
M10 X 1.25 = 20Nm plus (1) 90 degree torque angle ( +/-2 degrees ) But please wait for someone with your year to confirm. Credit to KTL for sharing the info.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Specify what type of Conrod bolts......
Frank, Nobody would be able to advise what torque value you would need without knowing the kind or type of rod bolts you are using. Porsche OEM rod bolts? ARP? Raceware? Etc. Please be more specific. Thanks. Tony |
Aftermarket would definitely have their specific torque requirements. At least the ones I bought. :-o
Manual is not up to date... Depending on bolts (BTW I would change 30years old ones)
Roland 930 Turbo '81 Too many modifications to list |
I have new oem bolts from porsche.
Do I attempt the second 90 degree torque? |
Racer
Do the bolts match Figure 1 or Figure 2?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
The above Technical bulletin is NOT applicable to your rod bolts. This if for updated 3.2/3.3/3.6 bolts which are 9mm. Your rod bolts are 10mm. Ignore the bulletin.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Racer
Good catch, Jeff.
Sorry, did not noticed which engine you have
