-   -   Getting Ready To Rebuild My Engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/925495-getting-ready-rebuild-my-engine.html)
impactbumper 08-14-2016 02:45 PM
please delete
going 3.6 please delete
DRACO A5OG 08-14-2016 03:16 PM
Cams and Rockers, I say John at DRC. Call him, he can guide you as to what is available for your needs and use.
He does beautiful work, price is reasonable IMHO:
http://img.photobucket.com/albums/v5...ps9la0hujs.jpg
hangar21 08-14-2016 03:34 PM
Sub'd! I'm trying to decide on which way to go for my 87?
All the best,
Terry
winders 08-14-2016 04:35 PM
German Precision in CA for the heads.
88911coupe 08-14-2016 05:20 PM
I used Competition Engineering and was very happy, well regarded shop. Had all parts measured by Zim like crank, cams and Pistons/cylinders.
winders 08-14-2016 06:27 PM
I hear bad things about Competition Engineering.....
impactbumper 08-14-2016 08:03 PM
Noted
Anyone had any experience with xtremecylinderheads?
gtc 08-15-2016 10:47 AM
Xtreme is great for porting, but pricey.
I sent my heads, pistons, cylinders, rockers, and rocker shafts to cgarr. I was Xtremely :D happy with his cost, communication, turnaround time, and quality of work.
No need for a bigger oil pump unless you're going crazy with the rest of the build.
Sboxin 08-15-2016 11:48 AM
Scott,
Are you talking about the one in Lake Isabella, CA . . . ??
I just spoke to a 356 guy yesterday who said they do good work . . . :confused:
But, people and circumstances do change . . .
Regards,
Tippy 08-15-2016 12:15 PM
If you don't send your heads to "cgarr", you will be ripped off. Forget all the other recs above.
Tippy 08-15-2016 12:17 PM
You'll probably be surprised how nice your crank will be. I bet a light polish will be all that's needed.
winders 08-15-2016 12:20 PM
Originally Posted by Sboxin (Post 9241621)
Scott,
Regards,
That would be them. As they say, you can't please all the people all of the time. Unfortunately, I hear they are pleasing just some of the people some of the time.
Plus, there are a lot of other places with stellar reputations to choose from that do the same jobs.
Techno Duck 08-15-2016 02:27 PM
Talking with a local shop to start a rebuild on mine next month. I am fairly certain i am going to go to a 3.4L . If you have to replace your p&c's for any reason its actually not much cost difference to increase displacement. You can send the cylinders to EBS and have them bore / replate for 3.4L. Then buy JE pistons, total cost going this route was about $2100. Add in a tune, cams and other odds and ends and its not too much more cost wise, a new set of euro p&c's is about $3k.
Might not be worth while if you are already at euro compression in terms of gains, but may be worth looking into further if you go 3.4L with matching 10.5:1 comp pistons.
Wish i didnt have to contend with CA smog, otherwise i would go twin spark and PMO's :(.
Rawknees'Turbo 08-15-2016 02:44 PM
Tippy is not one to brag (unlike me when it comes to a/c :D), but his cgarr done heads are on a monster power, turbo engine - aka: pretty good service endorsement right thar! :)
Tippy 08-15-2016 04:28 PM
HAHA, cgarr is the man on these.
vascott01 08-15-2016 04:38 PM
I sent my heads to anchor atlantic - Kudos for great work About – Anchor Atlantic Enterprises
I sent my cams to Elgin cams once again great work http://elgincams.com/ He will walk you through what you want. SC, sport grind etc if applicable to yours..
I used a local machine shop to clean balance crank, flywheel, pressure plate, rods etc..
If you can use a 930 oil pump...Go for it...
Looking forward to hearing about your work...I just went through this whole process myself awhile ago ...and be ready to fork over more and more money. I just about replaced everything.
Slippery slope mate...Best of luck
boosted79 08-15-2016 05:17 PM
x4 on cgarr for the heads, also rockers and shafts
impactbumper 08-15-2016 05:48 PM
I will talk to Craig. Thanks bunch.
You said it already have the euro p&c on the car, at this point I do not know how much more hp for the money 3.4 would give me. I was thinking may be 3.5 going similar route you suggested.
ITBs also on the table being thought of.
Thanks yous
I want to be in and out before temptations get a hold of me :D
Does anyone have a phone number for Craig "cgarr"? Is it G2 Performance in MI? Could not find him online.
jdbunda 08-15-2016 06:33 PM
Just PM him here, that is his Pelican ID.
I should add, he just did the heads for my rebuild, and while I can't report yet on how well they work, they look fantastic. :D
winders 08-15-2016 06:47 PM
This is just stupid......
