-   -   930 rebuild – The revival of my mothballed project (http://forums.pelicanparts.com/911-engine-rebuilding-forum/927868-930-rebuild-revival-my-mothballed-project.html)
Costa P 09-21-2018 03:59 PM
Originally Posted by jjeffries (Post 10189309)
Great stuff. That oil line fix is so cool/clever; I'd read the original version and neat to see others duplicate the process.
This might be a stupid question: how could the stub axle assembly get so cockeyed on the McPherson strut tube without having dented the tube, even if just minimally? Is there enough of a gap between the OD of the strut tube and the ID of the stub axle assembly/ring to allow for that to happen without physically deforming either?
Best regards, John/CT
Hi John.
I must add, that this oil line fix was extremely gratifying. It is almost surreal how the dent gradually disappears before your eyes as you circle the torch around it!
Iv been pondering on your questions about strut tube and stub axle.
It is possible that there is a localized dent in the tube.
It is also possible the stub axle press fit over the tube has stretched ever so slightly.
In fact, we had to press the stub axle 0.5deg past the intended final position to account for that amount of spring back once the pressure was released in the press.
Perhaps Iv been over eager to see this issue resolved.
In order to avoid any future doubts, I’ll recheck the straightness of the strut tube.
I’m thinking of placing it between centers and reinspecting it for any runout.
If the tube is rotating true ( ie it’s not bent) then everything is fine, right?
Any localized small dent is negligible since it doesn’t affect the sliding fit of the damper insert inside the strut, right?
And the addition of “RSR STYLE” gussets will ensure that the stub axle stays securely in its correct place, even if the press fit collar is slightly more loose than originally intended.
Jim2 09-22-2018 03:40 PM
The strut tubes aren’t particularly thick, or tough. I’ve come across stock, non race vehicles which showed signs of spindle defection on the tube. Your gussets should do the trick.
Good thread!
Costa P 09-23-2018 10:55 AM
Good thread!
Thank you Jim
Costa P 09-27-2018 11:08 AM
Originally Posted by Costa P (Post 10190377)
Hi John.
So, I setup each strut in a makeshift arrangement “between centres” and placed the dial gauge with magnetic base to crudely inspect and compare any runout in the LH and RH strut tubes;
http://forums.pelicanparts.com/uploa...1538067378.jpg
  • This (albeit crude) arrangement provided surprisingly stable/repeatable results.
    On the LH strut (the good one) I measured a runout of 0.5mm
    On the RH strut (the repaired one) I measured a runout of 1mm
  • Contrary to what one would assume, the mounting hole for the lower ball joint is not concentric with the strut!
    The "wobble", as indicated by the red centreline, was clearly visible as I rotated the struts.
http://forums.pelicanparts.com/uploa...1538068921.jpg
All in all, I’m quite happy with the repair and happy that the strut tube isn’t bent.
Next step, to add the “RSR style” gussets ;)
jjeffries 09-27-2018 06:08 PM
Good stuff.
Spenny_b 09-29-2018 03:24 PM
Nice work matey!!
Costa P 10-02-2018 11:01 AM
Originally Posted by jjeffries (Post 10197474)
Good stuff.
Thank you John
Originally Posted by Spenny_b (Post 10199427)
Nice work matey!!
Thank you Spencer
Costa P 10-02-2018 11:28 AM
External Oil Thermostat Housing (continued)
Originally Posted by Costa P (Post 10187667)
Hey Spencer, I have a hell of a lot of catching up to do!
I’m too scared to take my foot off the throttle now :D
Sneak peak into tonight’s progress;
http://forums.pelicanparts.com/uploa...1537389305.jpg
I borrowed the friction spanner from my mate Fred. It worked like a charm to loosen the 50mm cover. I’m preparing a special tool for the removal of the 38mm cover.
Did one or two other tasks as well , but I’ll wait before I write about those. Want to have a bit more considerable progress before I share ;)
So i've been trying to loosen the 38mm cover. My mate Brenton helped me out by turning a "coin" for me to the exact sizes required (Dia 37mm x 3.8mm Thk):
http://forums.pelicanparts.com/uploa...1538503828.jpg
I thought mild steel should be more than strong enough....after all, it is indexing into an Alu slot!
Take 1: :rolleyes:
http://forums.pelicanparts.com/uploa...1538504126.jpg
hmmm....I halted before causing damage to the Alu slot.
Take 2: :rolleyes:
Subsequently, Take 2 was repeated with assistance from my father in-law.
He applied the torque on the wrench after I applied heat to the housing via Mapp gas torch + a few healthy smacks to the coin with a hammer.
Equal fail....hence the frustration and omission to take more photos.
Busy rethinking the approach...to be continued!
Costa P 10-02-2018 11:59 AM
TIG Welding Practice Practice Practice
In preparation for welding the “RSR style” gussets, I need to practice running some beads on 3mm plate. (I am leaning towards using 3mm plate for the gussets)
This is also an opportunity to try out my new welding helmet with jumbo viewing lens :D
http://forums.pelicanparts.com/uploa...1538505804.jpg
Dremel setup with diamond wheel used to grind my tungsten
1st and 2nd weld that I put down (both @ 130amps).
Far from #weldporn but pretty ok for amateur DIY! :cool:
In hind sight, I omitted to brush the scale off the plates before welding.
This caused some splatter contamination on the surface of the welds.
Otherwise, the penetration and heat affected area looks ok.
http://forums.pelicanparts.com/uploa...1538505918.jpg
Pic of the back of the plate, showing a nice and narrow heat affected area.
http://forums.pelicanparts.com/uploa...1538506135.jpg
Need more practice practice practice...
Costa P 10-07-2018 10:17 AM
Spring Plate Disassembly
Originally Posted by Costa P (Post 10179341)
http://forums.pelicanparts.com/uploa...1536787443.jpg
The 930 is in good company at Café 9 Automotive :D
Full suspension refresh has been initiated and new parts from our host are on the way.
Feeling quite satisfied that the spell has been broken and I’m getting excited to see some progress again :)
Here is another pic of the work in progress on the 930...in good company with the Cafe 9 Automotive 935 :D
http://forums.pelicanparts.com/uploa...1538927219.jpg
Well…while I’m in there, might as well do some cosmetic freshening ups!
Spring plate disassembly - Take 1:
Nothing kills your enthusiasm (and ego) as quickly as a complete failure on executing what you initially considered to be a trivial exercise!
My failed attempt to disassemble the spring plate clamping bolt and adjustment bolt left feeling quite “humble”. My pneumatic impact driver made ZERO progress.
Spring plate disassembly - Take 2:
He held the spanner on the bolt head while I applied heat to the nut via the Mapp gas torch.
Once hot enough (boiling spit test), I attacked it again with the impact driver.
Still ZERO progress. Darn, I didn’t even need to restrain the bolt head, it didn’t even come close to rotating.
Time to retreat and read up on the subject in order to plan the next step.
Spring plate disassembly - Take 3:
After a quick pelican search on the topic, I learnt that these bolts are torqued at approx. 250Nm.
I also gathered that they you need a hefty power bar and you need to put your weight into it to break them loose.
My mate Brenton came to the rescue and lent me a power bar and some more hex sockets (24 & 36).
(...Oh, Brenton also lent me his Ingersoll Rand impact wrench as a backup (more about that in a moment)
This time I didn’t have a second pair of hands. So, I set everything up in the vice for a solo attempt.
The spring plates were placed on the bench with the nuts inboard and the bolt heads outboard.
The power bar was placed on the nut (inner side). I supported the socket with a make shift “v-block”, to keep the engagement nice and square on the nut, while I tug on the end.
My T-handle with power bar extension was placed on the bolt head (outer side).
Long story short – I tugged on the power bar and nothing. I added another pipe/extension for more leverage and tugged again….still nothing , but after witnessing the amount of flex on the power bar I aborted that approach.
Spring plate disassembly - Take 4 (The One with the Big Guns):
Time to call the Big (impact) Guns. My hopes turned to Brenton’s IR impact wrench.
For future reference, the vital Technical Specifications of the Ingersoll Rand 2135PTiMAX Series Impact Wrench - Nut-Busting Torque (1100 FT-LBS / 1490 NM) :eek: !!!
http://forums.pelicanparts.com/uploa...1538932217.jpg
WOW WOW WOW. This impact wrench is a BEAST! #peaceofcake #doesnt_bat_an_eyelid
It is difficult to explain it in words, you need to witness it working to understand.
Just the knocking sound it makes (compared to my mickey-mouse impact wrench) means business!
Costa P 10-07-2018 10:25 AM
http://forums.pelicanparts.com/uploa...1538932707.jpg
There you have it folks......not all impact wrenches are made the same.
You get what you pay for!
Costa P 10-07-2018 10:46 AM
Preparation of Suspension Parts for Replating
After the application of a variety of power tools with steel brushes ...voila!
http://forums.pelicanparts.com/uploa...1538933846.jpg
Making good progress to get everything prepared and ready for replating.
jjeffries 10-08-2018 07:55 PM
Costa, I will renovate my SC suspension this coming winter and keep thinking this would be a cool bit of mission-creep:
http://forums.pelicanparts.com/porsche-911-technical-forum/432703-modding-factory-spring-plates.html
One could of course just buy Elephant's elegant solution but clearly you have the skills and gear to do this all by yourself. Best, John
Costa P 10-09-2018 12:13 PM
MUST. RESIST.
John! Stop encouraging my urge, to dive head first, down the slippery slope!
Costa P 10-17-2018 02:44 PM
Take 1: :rolleyes:
Take 2: :rolleyes:
Take 3 - succeeded!
Iv documented the successful tool here:
http://forums.pelicanparts.com/porsche-911-technical-forum/1010620-diy-tool-external-oil-thermostat-cap.html#post10219008
Costa P 11-10-2018 12:46 PM
Suspension parts refresh and Zinc plating (continued)
It has been a while since my last update. In the meantime, I’ve slowly been completing various tasks and the results are coming to fruition.
http://forums.pelicanparts.com/uploa...1541877591.jpg
http://forums.pelicanparts.com/uploa...1541881515.jpg
Iv posted a detailed writup with lots of pics in the 911 Technical Forum
http://forums.pelicanparts.com/porsche-911-technical-forum/1012754-suspension-parts-refresh-zinc-plating-continued.html
Costa P 11-10-2018 02:12 PM
DIY fabrication of RSR style gussets for Bilstein struts
Spoiler alert!
The RSR style gussets turned out awesome :D
http://forums.pelicanparts.com/uploa...1541886656.jpg[/QUOTE]
I submitted a detailed write up with pictures in the 911 Technical Forum
http://forums.pelicanparts.com/porsche-911-technical-forum/1012772-diy-fabrication-rsr-style-gussets-bilstein-struts.html
BoxsterGT 12-27-2021 07:05 AM
Followed this with interest.
Any news or progress?
Len
Costa P 12-27-2021 12:16 PM
Long overdue update on the status of my project
Fellow Pelicanites,
It is time for a, long overdue, update on the status of my project;
I still can’t believe that my last post was in Nov 2018!
A lot has happened in between…not necessarily as per the original plan.
So where should I begin…
Current status (spoiler alert).
My 930 is running again!
https://www.instagram.com/tv/CXhFimwIyPZ/?utm_medium=share_sheet
I will fill in some of the details with subsequent posts.
The short story:- “ … insanity, is doing the same thing over and over and expecting a different result.”
In my case, my insanity, was biting off more than I could chew and sitting with a project burden that was dragging on for far too long.
The past 2 years have reminded me that life is short.
Driving & enjoying a stock 930, today, beats hands down an over ambitious project that is just dragging on and not materialising...
Regards,
Costa P
LukasM 03-13-2023 06:55 AM
Just went through this whole thread Costa, some nice engineering and good info on planned mods etc. Hope you have the car back together and driving again since that video from Cafe 9?
Originally Posted by Costa P (Post 10183815)
...And since everything worth doing, is worth over doing...
...after a little help from my friends at the hydraulic shop.....and voila!
M30x1.5 blanking plugs
http://forums.pelicanparts.com/uploa...1537118690.jpg
These look brilliant, I'll have to make something like that since I have 3 pairs of crushed oil lines I'd like to fix.
Do you know if the hydraulic shop had those available as a stock item (other than the airline chuck fitting), or were they custom made on a lathe? I'm in Europe so they should be even easier to find in M30x1.5, but no luck whatsover googling for them....
Cheers,
Lukas
