911 sc no compression in 3 cylinders
Have a project car underway ,engine with no compression in 3 cylinders on one side . What the most likely cause?
Old 09-18-2016, 11:51 AM
Do a leakdown test to find the source of the problem.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-18-2016, 12:23 PM
Straight shooter
Lapkritis's Avatar
Most likely? Jumped or broken timing chain on that side.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-18-2016, 12:54 PM
Yes, the cam setting isn't right...or its jumped time
Bruce
Old 09-18-2016, 01:21 PM
Crusty Conservative
silverc4s's Avatar
And/or you have 3 bent valves as a result...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 09-18-2016, 02:30 PM
