Sigurd's Avatar
CDI and twin spark
Can I use one 6 pin CDI box to fire both coils on a twin spark engine or do I need two?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 09-22-2016, 12:51 AM
I am sure you need two boxes.
I believe that the RSR used an 8 Pin Box but if you have an SC dizzy with a mag pick up you can use 2 x 6 Pin Units.
Old 09-22-2016, 01:36 AM
I have a twin plug set-up on my RSR motor. I use a single MSD to drive two coils wired in parallel. Very common and works well.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 09-22-2016, 03:59 AM
Puny Bird
Mark Henry's Avatar
I have no idea how to make the stock CDI work.
There are two warring camps on the MSD Twin plug debate, some say 2 boxes, some say one is fine.
Pros and cons
Single MSD box
Pro if the box fails not a big deal, other than the tow home.
Con, you may lose a hair of HP if you use only one box, but this point is debatable.
Twin boxes
Pro Many say more HP
Con if one box was to fail you would be running the engine on single plug, on a high CR motor that could result in engine damage.
My thought is for a race car 2 boxes, but for a street car, where losing a couple of HP isn't a big issue, a single box is just fine.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 09-22-2016, 06:53 AM
One MSD box can fire two coils, however the output is halved and we see the result on the engine dyno.
For best power, one needs two ignition boxes and two matching coils.
Not that its relevant, but the '73-'74 RSR (and all 935's) used twin Bosch CD boxes and twin coils.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-22-2016, 08:19 AM
Steve,
How much difference does it make?
We ran 3 x Twin Plug Rally cars with single MSD and Twin Plugs, they produced about 265 BHP fro 3.0SC engines with GE60 cams and 10.31 compression.
We never tried them with two units and I would be interested to know what improvement we could gain.
We ran a fairly tight plug gap and used NGK BP8ES plugs.
Old 09-22-2016, 09:06 AM
Puny Bird
Mark Henry's Avatar
Yes but what do you see? 1-3% or 10-15%?
I believe you have been asked this before with no answer.
Is the torque numbers also down? As an engine builder torque has always been more important to me than HP numbers.
If it's 3% in a street car it will not be a hill of beans.
In a race car, sure, of course you want every spec of HP you can gain.
In my narrow body 914 3.0 street car, I should dyno over 250hp, I'm not going to really care if I'm losing 5 hp.
Old 09-22-2016, 09:20 AM
As the real issue with 911s running high compression pistons is plug shrouding which will prevent combustion crossing the top of the piston at high engine speeds the effect will be reduced peak cylinder pressure due to incomplete combustion and this must impact on the torque being produced.
It is less important at lower engine speeds.
Early 2 litre engines are mush more adversely affected due to the deeper combustion chamber and taller piston crowns.
It will also limit engine speed which will have a significant impact on Horsepower.
The torque vs horsepower argument will never end but in reality I think that they are just two sides of the same coin.
For a race car I would always chase Horsepower matched to optimum gearing.
Old 09-22-2016, 10:20 AM
Sigurd's Avatar
Gentlemen,
thanks for the inputs. I know several are using one MSD box, but I am thinking of the Bosch, original, unit. As with the MSD, can I assume there wil be no electrical problems due to the higher current needed for the additional coil?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 09-22-2016, 11:05 AM
E-85 sippin drunk
turbobrat930's Avatar
I am running a M&W pro16 CDI. I LOVE it!!!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-23-2016, 08:14 AM
Chris,
Depending on CR and plug gaps (we run .045-.050 for more HP), I've seen 15-25 BHP differences between a single and dual CD boxes firing two coils.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-23-2016, 10:09 AM
Jonny H's Avatar
if you run one of our CDI+ boxes you will see similar gains to a twin spark setup, especially on the early engines due to the exact reason chris_seven gave above.
It is a true multispark, up to 10K RPM, unlike MSD which reverts to a single spark at 3400 RPM on a six cylinder engine. The second spark further ignites the fuel as it swirls in the chamber producing more power.
Steve W, have you dynoed that box we sent yet???
www.classicretrofit.com
Old 09-23-2016, 02:04 PM
Not yet; been doing a run of big (3.6-4.0) motors this year.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-23-2016, 03:51 PM
[QUOTE=
Twin boxes
.[/QUOTE]
I run two Bosch 6 pins and two coils on my 914-6 twin plug motor. Because of this fear, I have two switches in the cockpit so I can turn on and off the power to each box independently to check operation after start up each time I take it out. Obviously a box can die during a drive, but it is reassuring to be able to check operation of each box from the cockpit at will.
Tom
Old 09-23-2016, 07:00 PM
SoyRacer's Avatar
Might I ask . . . - Why not just run Electromotive and be done with all of it?
Simple design, full tuning capabilities and pretty much bulletproof .. ..
No distributor limitations, no moving parts to wear/fail etc etc
R
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 09-24-2016, 04:02 PM
Sigurd's Avatar
R
Posing factor! Coil packs does not looks as good as a twin spark distributor
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 09-24-2016, 11:14 PM
SoyRacer's Avatar
"Look as good" ? .. .. .. different..... maybe
I've had great success with them on many builds.
It's all subjective - Many factors go into what works for some and don't work for others. For me --> they work well
R
1973 Porsche 911 RS
Old 09-24-2016, 11:44 PM
Sigurd's Avatar
R
Nice!
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 09-24-2016, 11:49 PM
I am surprised that single and twin boxes make so much difference but have never tried to use a Twin Box.
Does the fuelling need to be changed when you add a second box?
I am not sure I understand why losing a plug causes engine damage, I can accept it may lose some power and effectively run a little rich but what else would happen?
Old 09-25-2016, 02:01 AM
Detonation
Tom Butler
1973 RSR Clone
1970 911E
Old 09-25-2016, 06:12 AM
