Slumlord
Porsche_monkey's Avatar
Jerry Woods Chain Tensioner Mod
In his book Wayne says 'an emergency retaining collar' mod is available at 101projects.com.
Anyone know where on the sight it might be found. I had a look and can't find it in the tech articles.
Old 04-06-2004, 05:33 AM
Super Moderator
cstreit's Avatar
PBH.
It's an extraordinarily simple device. Two aluminum collar halvs that clamp on to the tensioner shaft to prevent it from collapsing all the way. Highly recommended.
http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=tensioner+collar
The collar is the device on the lower left.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-06-2004, 06:19 AM
Friend of Warren
I used to run them on my 72E. Inexpensive insurance!
Kurt V
Old 04-06-2004, 06:21 AM
Slumlord
Is that the right part for hydraulic tensioners?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-06-2004, 06:35 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The Pressure fed tensioners don't need them. And I don't belive they fit anyway.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-06-2004, 06:39 AM
Slumlord
Waynes book, page 170, clearly says there is a retro-fit for hydraulic tensioners even though they almost never fail.
Maybe he has never posted it?
84 Cab - sold!
Old 04-06-2004, 07:30 AM
i've never seen one. the early tensioners, like the one pictured are hydraulic, but reservoir style, not oil fed.
206 637 4071
Old 04-06-2004, 08:27 AM
Slumlord
I guess only Wayne knows what he was referring to...
Wayne are you still in Hawaii?
84 Cab - sold!
Old 04-06-2004, 08:28 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
If you look at the PP site it says: Not for pressure-fed tensioners
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 04-06-2004, 08:40 AM
Doug Steinel's Avatar
I asked Wayne a few months ago about using the collars on the Carrera tensioners... he said they wouldn't fit but he is working on a technical paper on this. Expecting it sometime soon. PBH, I have a pair of these collars if you want them. I decided to go to the Carrrera update so I didn't use them.
77 911, 3.0L
Old 04-06-2004, 10:06 AM
ischmitz's Avatar
I could use a set. What do you want fot them Doug. I have a 2.0S motor that is going into the track-914
Cheers,
Ingo
Old 04-06-2004, 10:10 AM
ischmitz,
If you want them, you can have them for half the price our host charges... $15. PM me your address and I will mail them to you. I have everything they come with: instructions, the 2 collars, a gauge to space them properly and an allan wrench to tighten them up. When you get them, just mail me the $15.
77 911, 3.0L
Old 04-06-2004, 02:36 PM
Bill Verburg's Avatar
I used them on my '72 w/ the old style, sealed, tensioners. They saved the engine.
Bill Verburg
Old 04-06-2004, 05:37 PM
I am one of the members who prefers the old tensioners, but, then again, I look at all the tensioners are repair/replcement items. Like a timing chain, they have a lifespan so I would rather have the benefit of the collars. I can tell you, from practical experience, they will give you enough notice, when the tensioner has failed, so that you will know its time to pop the back covers.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 04-08-2004, 05:34 PM
Author of "101 Projects"
Wayne 962's Avatar
Hi there. You guys are all on the wrong track. There indeed is a mod that Jerry Woods showed us duirng his engine rebuild class. It involves taking apart the Carrera chain tensioner and placing a small stop-piece on the bottom. This limits the overall travel of the tensioner and makes it virtually impossible for it to skip a tooth.
I started to do this write-up, but I never completed it. Maybe in the near future - it's quite interesting.
-Wayne
Old 04-08-2004, 05:51 PM
Now in 993 land ...
aigel's Avatar
Basically, instead of adding a shim on the outside of the shaft you now limit the shaft travel inside, in the bottom of the tensioner by disassembling the tensioner and inserting a shim. You need to measure first, to determine the thickness needed. Woods does this on all his rebuilds using carrera tensioners. The last straw to make them truly bullet proof. I think you can use 5/8" brass tubing to fab the shim. The only disadvante is that you won't be able to use the grenade pin because the tensioner will not collapse completely any more.
I am about to upgrade mine and do the mod. I will take pictures and post.
George
81 SC (sold)
Old 04-15-2004, 01:28 PM
Slumlord
I am not sure how you assemble this if the shim is in place, since you can't compress it anymore.
84 Cab - sold!
Old 04-15-2004, 01:38 PM
Now in 993 land ...
aigel's Avatar
Of course you can still compress it and install it. The travel is however limited so the tensioner can't collapse. Only in it's fully retracted state (collapsed) is when you can insert the grenade pin. You will have to install the modified tensioners like you do the old ones, with a C shaped tool holding it together.
George
81 SC (sold)
Old 04-15-2004, 02:34 PM
Slumlord
Oh......I see.
84 Cab - sold!
Old 04-15-2004, 02:59 PM
Jubbie's Avatar
George or Wayne,
Did you ever get around to document this mod to the Carrera tensioners. I would be interested since I am there now on the rebuild.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 11-27-2004, 10:14 AM
