Cam Recommendation for 3.2SS
Hey all,
I have used the search function and looked at lots of cam profiles but wanted to post this up to see what you all thought.
Motor
3.0 with 98mm Nickies 9.5 JE pistons
Stock crank, rods, oil pump
Heads intake opened to 38mm
46 PMO's
123 USB Dizzy
SSI headers BB Single out muffler but may change to M&K
Car is going to be street driven but not a DD
We would like a cam that has good mid-range but can still put the power down at the upper end.
options I have been considering.
964 (Can regrind current)
These would require new billets
GE-40
Sprio at Redline own grind similar to the 964
Thanks in advance
Old 11-10-2016, 09:15 AM
GE40, Solex, Mod-S would all be decent choices.
Make sure your exhaust can support which one you choose.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-10-2016, 05:38 PM
Thanks for that Steve will chat with you later via email or phone...
got parts on order with you
Old 11-10-2016, 11:26 PM
Cory M's Avatar
timely post, I've got an almost identical engine I'm going to be using soon, it currently has CIS and 964 cams but I'm looking at changing to 46mm Webers and new cams that are optimized for the carbs
Old 11-11-2016, 08:09 AM
non-whiner
mreid's Avatar
I have almost the exact same engine (10.5:1 compression). I'm using DC80's and they scream.
"Too much is just enough."
Old 11-11-2016, 10:49 AM
I made 204 WTQ from 3500-5000 and 192 WHP at 6500 on a Mustang Dyno with the same engine on 4R CIS with 964 camshafts. Excellent power band for a street car.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 11-11-2016, 12:45 PM
Under the radar
Trackrash's Avatar
On the one hand you have great breathing on your intake side, but are limited on your exhaust side, IMO.
I guess you need to decide at what RPM range you want the motor to work best in.
In my case my motor is an 3,0 SC with JE 9.5s, large port heads, and for now 40mm Webers. I want mid range torque so I chose John Dougherty's GT-2 102 cams. According to John they will still pull to past 7,000 rpm, but peak around 6,000.
You might want to contact John and discuss your needs. Camgrinder on this forum. Or Dougherty Race cams, Dougherty Racing Cams
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-11-2016, 01:05 PM
all great recommendations.
I am taking them all as options at this point. I have spoken with Spiro (Redline Racing Cams) but not John yet.
I want this motor to work best in the mid-range with the ability to get in the upper end and still make decent power but the mid is where we will drive it most
Old 11-11-2016, 08:14 PM
decided on a set of GT-2 102's from John.
Also had the stock ones reground by Spiro to 964 spec may try them may not.
still debating on what to do with the exhaust.
the SSI's I got are new and would prefer to use them but also want heat.
Muffler needs to be single out because we already painted the bumper and it only has the single cutout
Old 02-18-2017, 02:13 PM
