Member 911 Anonymous
Hey Fellas,
Okay, just mic'd the crank shaft 1-7: (#1) 2.3615" ( thrust bearing, width is 28.00MM) (#2) 2.3613" (#3) 2.3612" (#4) 2.3612" (#5) 2.3612" (#6) 2.3612" (#7) 2.3612" Maximum wear limit is 2.3600", so she is within spec. New Shafts per Spec are 2.3610"-2.3618" I have a choice of Porsche bearings vs Porsche GT3 RED bearings which are 0.0005" thinner. What would you do?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
You need to know the diameter -ID of the bearings in the case before you can decide.
Can't know clearance without both dimensions------
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
Will get a STD bearing and measure with bore gauge to be absolutely sure.
Spoke to Ollie's they stated my case is straight and true within spec. Thanks for your input.
I am not expert but went through something similar a while ago.. I spoke with the guys at EBS... after speaking with them, and considering what I was using the motor for, I decided to go with the stock genuine Porsche bearings. |
That is the path I am taking as well.
REDs sound nice but not for largely street use 900-3000RPMs
