2.5 ss mfi
Considering building a 2.5 SS MFI engine. I have the MFI. Looking for a rough idea of a build list to include whether I should use a 2.7 case or an early 65 aluminum case that has already been opened up for 90mm spigots and has a MFI pump pedestal already installed. This will be a sport engine, not a race engine. Might incorporate the Rothsport
high butterfly TBs...and not sure if I want to twin plug it. This will probably end up in a SWB 911
Henry?
Speedo
Old 01-17-2017, 05:43 PM
Turbonut
Raceboy's Avatar
I love the idea, great engine!
If you decide to go with 2.7 case I would be interested in your aluminium case for my 2.5ss twin-turbo engine...
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 01-17-2017, 09:11 PM
Response here has been amazing...
Not much SS 2.5 or 2.8 interest?
Realized I have all the components and machining done to start my 2.7 RS MFI spec engine. Wouldn't take much to shift that towards a SS 2.5...might be able to use that same pump set-up, just need some better CR pistons than the 8.5 RS Mahles.
Speedo
Old 01-18-2017, 05:38 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The short stroke 2.5 or SS 2.8 engine are very cool if your goal is RPM. Spinning those little engines is a thrill.
That said, I would generally advise building the largest engine you can based on your application.
Building a high RPM engine requires compromises (always to low end) but those compromises also include noise, engine life, fuel mileage, challenging heat distribution and a general sense of frantic shifting.
Longer stroke engines tend to offer an ease of driving missing from peaky engine.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-19-2017, 09:02 AM
