Straight shooter
Lapkritis's Avatar
ARP also uses standard thread nuts in many applications. If you tried to install backwards into a metric base with the imperial end, you'd figure this out quickly.
Sent from my SM-T580 using Tapatalk
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-13-2017, 10:13 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Thanks for the info but for this specific TOPIC, OP's and my ARP heads studs for our 911's are METRIC on both ends. I just verified it.
'85 Carrera Targa
PCA/POC
Old 01-13-2017, 01:11 PM
Straight shooter
Lapkritis's Avatar
Thanks for checking. I wasn't about to!
Old 01-13-2017, 01:28 PM
