Member 911 Anonymous
DRACO A5OG's Avatar
Question Crank Shaft Specs which bearings?
Hey Fellas,
Okay, just mic'd the crank shaft 1-7:
(#1) 2.3615" ( thrust bearing, width is 28.00MM)
(#2) 2.3613"
(#3) 2.3612"
(#4) 2.3612"
(#5) 2.3612"
(#6) 2.3612"
(#7) 2.3612"
Maximum wear limit is 2.3600", so she is within spec.
New Shafts per Spec are 2.3610"-2.3618"
I have a choice of Porsche bearings vs Porsche GT3 RED bearings which are 0.0005" thinner.
What would you do?
'85 Carrera Targa
PCA/POC
Old 01-26-2017, 08:16 PM
prschmn's Avatar
You need to know the diameter -ID of the bearings in the case before you can decide.
Can't know clearance without both dimensions------
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 01-28-2017, 05:45 AM
DRACO A5OG's Avatar
Will get a STD bearing and measure with bore gauge to be absolutely sure.
Spoke to Ollie's they stated my case is straight and true within spec.
Thanks for your input.
'85 Carrera Targa
PCA/POC
Old 01-28-2017, 11:54 AM
Originally Posted by DRACO A5OG View Post
Hey Fellas,
(#2) 2.3613"
(#3) 2.3612"
(#4) 2.3612"
(#5) 2.3612"
(#6) 2.3612"
(#7) 2.3612"
What would you do?
I am not expert but went through something similar a while ago.. I spoke with the guys at EBS... after speaking with them, and considering what I was using the motor for, I decided to go with the stock genuine Porsche bearings.
Old 01-30-2017, 05:59 PM
DRACO A5OG's Avatar
That is the path I am taking as well.
REDs sound nice but not for largely street use 900-3000RPMs
'85 Carrera Targa
PCA/POC
Old 01-30-2017, 06:26 PM
