Cracked Cylinder Head... Repairable/weldable???
In the process of having a 2.8 race motor rebuilt and this showed up... Builder thinks maybe it was torqued down on an uneven surface.
Any thoughts on if this can be welded up and repaired?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
The ones up top don't look bad but that big one, yikes! Not in an extremely sensitive area so I would think a repair is possible with the right skill set. Only problem is how deep is the crack and what kind of adverse effects could be caused by it. Worth it to build the whole motor with a questionable head or just replace it?
Personally I think it would cost less to replace it then to risk using it and having a problem, that is of course unless you are doing all of the work yourself and don't mind re-doing it, but I'm sure your builder doesn't work for free so... Cost of a new head vs cost of another engine rebuild? Not sure I would go down the repair path, but hopefully someone with more experience will chime in with a more definite answer. $.02 J
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! |
...Thanks, part of the problem with replacing a head other than finding one is it will need to be twin plugged and then ported to match the other 5.
I'm lucky to be broke enough to not have those problems, but if it was mine, I'd replace it. Good luck! J
Yes if it needs replacing for sure I will. I've sent a photo to Walt at Competition Engineering. He is not certain but thinks he could bandaid it up with a weld. I trust his skills so will probably send him the one head and then the rest if they will need to be resurfaced...
Yeah Walt is the man to ask for sure! Like I said being in a non-critical area it seems like it would be OK. Hopefully Walt comes back with good news for ya!
Racer
Competition Engineering? I can think of five places I would go before them and I don't like two of those.....
I would check with German Precision in CA or Extreme Cylinder Heads in Florida.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
OK, All I know is that when I did my engine on my 3.0 a 10-12 yrs back Walt took good care of me.
Chain fence eating turbo
No expert, but I think that head is done. The fact the cracks propagates on a few different surfaces tells me its deep.
But, until you grind into the crack, it's a guessing game. |
I suggest getting the head crack tested, even x-rayed to assess the condition of the head. If okay, have it welded. CE and other reliable Porsche people will have the resources to get this done.
MHO, Sherwood |
Try not, Do or Do not
If it can't be fixed, I have a plethora of core heads, the ability to twin plug one head and match the ports. My guess is $250 (CIS head) for a core head, $200 to port the exhaust and intake and about $ 125 to twin plug one head. These crates are full of heads......
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-18-2017 at 04:48 PM.. |
Thanks Henry. For what it's worth although I'm running carbs these ar MFI heads date coded 71. Not that imporant but I may at some point decide to do fuel injection so if I should have to start with a core head it would either be an MFI head or an MFI injection port added. ...wouldn't mind it to be a matching date code just for grins.
Send it and I see what we can do.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
That head is an ashtray. I bet Henry has a 71 head in that treasure trove.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
That head will make nice beer cans.
