AES AES is offline
Cylinder base gaskets
Some cases seem to use more effective cylinder base gaskets than others. I currently have an '86 3.2 and a 91 3.6 case disassembled. The 3.2 uses a simple flat base gasket while the 3.6 has a groove, flycut into the case wall for an o- ring gasket.
Why, the different designs, does the 3.6 pressurize the crankcase that much more, or is it an example of the factory engineers over designing something(probably not likely), does it make any real world difference, is it a track only thing?
Old 01-15-2003, 05:38 AM
Jeff Curtis's Avatar
Copper or Viton?
I dunno why Porsche would've done this except that maybe a Viton "O"-ring is quite a bit cheaper than a copper base gasket?? ...or they just wanted a change.
Another reason that would probably make more sense is that an "O"-ring would seal the cylinder better when compared to aluminum/copper/aluminum.
Jeff Curtis
1991 911 C2
"Track Rocket"
Old 01-16-2003, 03:03 AM
AES AES is offline
Thanks for the reply Jeff. One mechanicaly gifted friend suggested that the bigger, higer compression engines pressurize the crankcase more necessitating a better seal. I dunno either, but it seems that a lot of effort went into a better seal.
Old 01-16-2003, 03:59 AM
Bill Verburg's Avatar
The bigger cylinders leave very little meat for the flat 3.2 type seals. Here's a pic of my 102mm RSR cyliner base, as you can see not much sealing surface.
Bill Verburg
Old 01-19-2003, 02:56 PM
Super Moderator
cstreit's Avatar
Bill,
I'm not familiar with the later cylinders... What are the threaded portions in the cylinder walls for?
MAN those pistons must be as big as freekin coffee cans!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-19-2003, 03:39 PM
Knock sensors. Another reason to covet the later engines.
Chris, are you going to keep us updated on your progress? I would be very interested in a pic of your new pistons like this one, showing the wrist pin.
Nevermind I just found the ones from Nov. Which also coincidently show the meatier sealing shoulder on the 95mm cylinders.
Bill Verburg
Old 01-19-2003, 03:49 PM
nick-moss's Avatar
My '74 2.7 has a Mahle 92mm P+C conversion. There are no base or head gaskets save for an aluminium shim at each base to set the deck heights
Spot the deliberate mistake in this photo
Nick Moss - RGruppe #318
early911.co.uk
Old 01-20-2003, 03:39 AM
Is that the famous twin piston/bore engine? Though not a mistake that also looks like 993 studs?
Bill Verburg
Old 01-20-2003, 03:56 AM
nick-moss's Avatar
Bill, I'm not sure of the studs, but they are genuine Porsche, but no that's not the mistake
early911.co.uk
Old 01-20-2003, 03:58 AM
thesey914's Avatar
Cylinder upside down?
Old 01-20-2003, 04:56 AM
Started at the wrong end
Bill Verburg
Old 01-20-2003, 05:34 AM
nick-moss's Avatar
thesey914 gets the prize. The first barrel I put on upside down, and didn't realise until I had timed both the cams. At least I got extra practice at that!
early911.co.uk
Old 01-20-2003, 05:38 AM
thesey914's Avatar
YESSSsssss
Sorry to hear about the unexpected tear down -Nick
Old 01-20-2003, 05:47 AM
nick-moss's Avatar
It only took 90 minutes to sort out
early911.co.uk
Old 01-20-2003, 06:20 AM
