2.7RS questions
Hi to all, i may have a lead on a 1976 2.7S Carrera. Included is a new set of Mahle 2.7RS pistons/cylinders.
Was wondering if the stock cams will cope with the 2.7RS pistons and Webers. Should i fit my 2.2S cams?
Thanks!
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 01-15-2003, 08:42 PM
Hi Wayne, serial number is 6460379.
Is that help?
Sabin
PCA Member
1978 911 SC Targa
Old 01-16-2003, 04:43 AM
nick-moss's Avatar
6460379 is a 2.7 911S US49 + Canada Coupe 121 Kw (165 Bhp) motor. That will be a mag case.
What injection are you using?
Nick Moss - RGruppe #318
early911.co.uk
Old 01-19-2003, 03:38 AM
> What injection are you using.
Plan on fitting Webers with stock CIS pistons, waiting for a set of RS oe JE pistons, more suitable to E-cams and Webers.
> That would be a magnesium case.
Good or bad thing? 7R?
The case hase been case-saved as the seller says. Is there any easy way to check? The engine is out.
Thanks!
PCA Member
1978 911 SC Targa
Old 01-19-2003, 05:47 AM
nick-moss's Avatar
I'm sure you will find plenty of comments on the 7R cases in the BBS, do a search. I have a 2.8 litre, 240HP motor with 10.5:1 and MFI, no problem with my 7Rs
early911.co.uk
Old 01-19-2003, 05:51 AM
Super Moderator
cstreit's Avatar
Wayne,
If you're in MAUI, what the HE11 are you doing on the board. Get some sun man!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-19-2003, 10:33 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
AMEN to that cstreit. If I was there there's no way I'd touch a computer..
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-19-2003, 08:53 PM
