New-ish 911SC Targa Owner
pampadori's Avatar
Visible difference between 2.2 and 2.4/2.7 crankshaft
I have a 930/52 motor apart that has been a mix and match of various parts, including a 6 bolt crank. I'm trying to confirm what the crankshaft is though, 2.2 or 2.4/2.7.
Is there a way for a layman to confirm which crank is which by just looking at the crank?
Old 02-05-2017, 10:14 AM
2.2 cranks are 66mm stroke whilst 2.4/2.7 are 70.4mm
Old 02-05-2017, 10:53 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The easiest way to tell the difference between a 2.0/2.2 crank and a 2.4/2.7 crank is by looking at the flywheel flange. They all have six flywheel bolt holes but the 2.0/2.2 flange has two oil galley holes and the 2.4/2.7 crank only has one.
This makes identifying the crank easy even when the crank is in the case.
Just remove the flywheel.
2.0/2.2
2.4/2.7
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-05-2017, 11:59 AM
On the 2.4 and 2.2 sitting together, the drill holes for the rod oiling on the 2.4 are more than twice the size of the 2.2.
Bruce
Old 02-05-2017, 01:43 PM
pampadori's Avatar
That's easy enough. Thanks fellas!
Old 02-05-2017, 02:25 PM
