There are various types of fasteners used on Porsche engines. I am still confused over when to use the various types of washers (alum crush, copper crush, spring, steel, etc) and nuts (regular vs. Nylock). I have been told not to use Nylocks on any internal bolt, which makes sense, but the rest ???
Bill Leonard |
Irrationally exuberant
When I'm disassembling something I save the fastners so I know what type of fastener to use. I've seen several types of engine perimeter washer&nuts so I think the fasteners may change over the years even for the same application - or someone has worked on the motor.
Here are the types of fasteners you'll see in a 911: aluminum crush washers: act as a seal, used in conjunction with a locking nut solid washers: Used with locking nuts or another locking washer. spring washers: aka wavy washers, a type of lock washer. Used with normal nuts nylocs: Used with aluminum crush washers aluminum sealing rings: Used on aluminum (motor) and oil line banjo bolts copper sealing rings: Used on steel (oil tank) "under sized" nuts: some nuts take a smaller wrench than normal. 10mm nuts usually take a 17mm wrench but the 10mm nuts on engine carrier and transmission take a 15mm wrench. 8mm nuts usually take a 13mm wrench. The heat exchangers sometimes use 8mm nuts that take a 12mm wrench. Just to get the ball rolling, here are some combinations I've seen. Keep in mind that they may be wrong i.e. fastener was changed in the past and replaced with the wrong type. Hopefully, someone will jump in here and set things right. aluminum crush washer + nyloc: low torque gasketed covers aluminum crush washer + metal locking nut: engine perimeter nuts, 915 transmission perimeter nuts solid washer + metal locking nut: engine perimeter nuts aluminum crush washer + nyloc: engine perimeter nuts, 915 transmission perimeter nuts split lock washers: used internally on 915 transmission, some CV joint bolts, 911 engine carrier That's all I have time for now... -Chris Last edited by ChrisBennet; 01-21-2003 at 09:50 AM.. |
Author of "101 Projects"
The later-style engines used egg-shaped locking nuts for the inside of the engine - I recommend these for places like mounting your timing chain housings...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
A couple of local porsche dealers told me that they do not have egg-shaped locking nuts; but gave me the regular nuts for '73. They looked up the parts list and said "This is it!" What is the part number of egg-shaped locking nuts? Are you selling it @ PelicanParts? I'd rather have the nuts than $20 coupon!
