Altenator stuck
Wanted to remove my altenator to clean up my fan housing but it seems stuck ! Tried to tap it out with a nylon hammer on the bolts. Can I use a drift and tap the alt itself?
Old 03-03-2017, 08:06 AM
The method I use (as found here in the Forum) is:
Place a heavy towel/rug on the floor (garage floor is better).
Hold your alt/stator assembly horizontal to the floor, shaft-side down (be sure all the nuts are removed).
Tap the stator on the towel/floor, going "around the circle" after each tap.
Watch as the alternator starts coming out.
You can tap the alternator a bit if you want, but it's been unnecessary when I've done it this way. Good luck.
Old 03-03-2017, 08:22 AM
Thanks for the encouragement man that sucker was tight!
Old 03-03-2017, 08:48 AM
Under the radar
Trackrash's Avatar
I had to soak mine for a week with PB blaster. Be patient, if the bang on the floor method doesn't work at first.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-03-2017, 01:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Last resort: you can unscrew the Allen bolt from the fan side of the alternator.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-03-2017, 03:11 PM
Under the radar
Trackrash's Avatar
Be careful with this approach. Your alternator will come apart when you remove the long bolts. Before you attempt this remove the brushes. Then you won't damage them as the alternator cases will separate. AHIK.
Gordon
Old 03-03-2017, 06:09 PM
I guess I should have been clearer. Unscrew one Allen bolt at a time. Then replace it. This technique will free any corrosion holding the bolts in place.
Remember, the fan housing is far more valuable than a used alternator.
Henry Schmidt
Ph: 760-728-3062
Old 03-03-2017, 07:10 PM
Thanks Henry I did loosen the Allen screws then realized the alt might separate, squirted PBS blaster on it and tapped harder on the bolts with the nuts on finally it came off! Now I'm trying to decide weather to paint or just polish
oops double
Old 03-04-2017, 02:13 PM
