Still here
Cylinder scuffing
What causes this ?
![]() Does the rest look OK ? ![]() ![]() ![]() ![]() ![]() ![]()
abit off center
Is it a stain or can you feel a difference?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
scuffing
Marks like that come from a motor that has sat for awhile.Dirty oil & rings getting a little rusty from moisture.Then they lit it up bringing it back to life.That motor was tight and cracked loose when they turned it over.Fred
Still here
Craig,
Feels a bit rougher. Fred, Yeah, that's probable. This is from a basket case 78 engine I'm tearing down. Here's the corresponding piston. ![]() ![]() ![]() ![]() BTW what's the trick to splitting the case ? Heat ? Hours of hammering with a mallet made no difference. Or is it possible I missed one nut ? Last edited by pmax; 04-02-2017 at 09:38 PM.. |
99% you missed "the secret one". Have you got Waynes book?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Still here
Case split as per Mr Dempsey's excellent book and some perseverance and choice words ! Next goal is to see if this engine's worth rebuilding or better off as parts fodder.
