wprater's Avatar
installing gearbox bell crank after motor is installed?
got my motor finally dropped in! after toquing down the CV joints I noticed I'd forgotten to install the bell crank on the gearbox!
am I screwed? or is there a chance I can jack up the trailing arms and install?!
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 08-08-2017, 10:51 PM
safe's Avatar
Throttle bell crank?
Sure, try to jack up the trailing arm or loosen the rear engine mounts to lower the engine a bit.
Magnus
Old 08-09-2017, 02:08 AM
SoyRacer's Avatar
If it's the 78 SC you should have an Aluminum 915 transmission so you can remove the bellcrank stud from the transmission. Use an 8mm wrench on the end where the cotter pin goes through. Then just run it back in as an assembly (don't forget the inner bushing) and put some blue locktite on the threads on the way back in.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 08-09-2017, 03:49 AM
safe's Avatar
Careful, at least on a G50 trans fluid will leak out if you remove it.
Magnus
Old 08-09-2017, 04:11 AM
Member 911 Anonymous
DRACO A5OG's Avatar
915, I just disconnected the shock and safely jacked up the arm and it dropped right in. again be safe.
'85 Carrera Targa
PCA/POC
Old 08-09-2017, 10:14 AM
wprater's Avatar
hmm, maybe I should try the jack stand method first made a big enough mess here already.
1990 911 Carrera 2
Old 08-09-2017, 01:28 PM
wprater's Avatar
got the bell crank installed and used the method with the 8mm to remove the post. the 915 is not threaded all the way though, FYI.
1990 911 Carrera 2
Old 08-09-2017, 09:14 PM
DRACO A5OG's Avatar
Yeap, not a G50. Good Job
'85 Carrera Targa
PCA/POC
Old 08-10-2017, 04:45 PM
