Left heat exchanger Hotter then Right heat exchanger
Why does my left heat exchangers have hotter temps the right heat exchanger. I have SSI heat exchangers and I can touch right side after 15 min at Idle. No way can I touch left drivers side. Way to hot. Is it maybe my carbs on drivers side running to lean?
Sounds like the right side isn't running properly
Bruce |
Depending on what you have for Induction the throttles are out of sync.
regards |
I have Zenith 40TIN carbs with tall PMO manifolds
Sync the carbs with a Unisin and that will change the exhaust temp also the way it runs so you may have to mess with the Air Bleeds as well.
You have this right: hot drivers side is running leaner than cold side (richer)
I will have my mechanic sync and adjust carbs. Thanks
