some_german_guy's Avatar
How in blazes is this exhaust nut supposed to come off?
My 79 SC is on the lift and I'm removing all the bits and pieces around the engine, trying to strip as much as possible before dropping the motor and rebuilding it.
All the Allen and hex bolts holding the SSIs to the head came off without major fuss, but one hex nut has me stumped. It is the outside nut on the middle head on the passenger side (see pic). I've tried every tool under the sun but nothing comes close to even engaging the nut. Is there some weird shaped Porsche tool needed to get that bastardly nut off? Wayne's books don't talk about it and a search of the forum didn't really get any hits. Help.....
Bernd
Old 05-10-2017, 03:19 PM
Did You try a SSI headers wrench?
Old 05-10-2017, 04:15 PM
I guess whoever installed the SSIs for the previous owner failed to leave the wrench with the car....
That is one odd looking wrench. I'll hit home depot and buy an offset box wrench and take it from there, maybe use the MAP torch to bend it and replicate that SSI wrench...Thanks much foe the quick reply!
Bernd
Old 05-10-2017, 05:23 PM
Perpetual Reassembler
2jmotorsports's Avatar
I have stock heat exchangers but I managed to get the tricky nuts off with this style of wrench:
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 05-11-2017, 07:41 AM
Chain fence eating turbo
That's an offset box
Old 05-11-2017, 08:05 AM
safe's Avatar
Sacrificial wrench and a mapp/propane heater will make tools that fits most places. Have a bunch of then...
Magnus
Old 05-11-2017, 08:47 AM
I like the way you're thinking.....
Went to Sears and bought a set of deep offset box wrenches but they wouldn't do the job (the angle is just too severe with the SSIs, but should do for stock exchangers). Then a light bulb went off and after sacrificing a 12mm socket, some bar stock and a few feet of welding wire...voila, the perfect tool for that cursed nut. I didn't even have to heat treat the bar stock to keep it from bending, the nut was pretty loose from multiple heat cycles with a propane torch and subsequent liberal application of penetrating oil, it came right off...
Bernd
Old 05-11-2017, 09:35 AM
crg53's Avatar
Buy on of these, that's what I use, works a charm.
Old 05-12-2017, 06:30 AM
Harbor Freight for sacrificial tools
Old 05-12-2017, 06:45 AM
fred cook's Avatar
SSI wrench
I have the SSI wrench if you would like to borrow it.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-13-2017, 05:56 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I have a few as well.
Email me if you need one.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-14-2017, 11:48 AM
The 9 Store
The ssi wrench is a good one to have in your toolbox.
All used parts sold as is.
Old 05-14-2017, 05:07 PM
