3.0 CIS Kjetronic fuel distributor upgrade / more fuel
Hi
I rebuild my engine with a more powerfull setup
high compression piston
schrick camshafts
twin plug
etc ....
my tuner is working on the engine to try t get the max from the CIS
please ... I know later I can achieve much more with PMO or EFI ;-)
this tuner is works for years on rally engine with carbs and pmo (not only 911)
regarding the AFR, we need some more fuel to get better performance
testing with the WUR adjustment and pressure control on the head have been done, but results are not good
so we are looking a way to give more fuel to the engine
is it possible to rebuild the fuel distributeur and adjust it to deliver 10% or 20% more fuel ?
any reputable company to do this ??
I will appreciate your help and feedback
thanks
Florent
Old 06-20-2017, 01:30 PM
E-85 sippin drunk
turbobrat930's Avatar
Send Brian Bodart (Rarly8 on these forums) a PM. He is the 930 CIS goto guy. And if he can not help you, chances are, he will know who to send you to.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-21-2017, 05:23 AM
Under the radar
Trackrash's Avatar
This has been discussed. Not sure if it was here or on Rinnlist. I guess it was so long ago that it doesn't show up in a search. Hopefully one of the moderators will know.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-21-2017, 12:25 PM
I find a local tuner focused only on Bosch Kjet L jet etc ... upgrade
my tuner had a long discussion
he seems to know what he's doing and good reputation
they validate together the increase (10-12 %)
the guy will do a chart before and after so we can check
and the AFR / lambda will be the final judge
we are currently at 235 HP
and the car can gives more ... but need more fuel
I will tell you
Old 06-26-2017, 11:57 AM
Walt Fricke's Avatar
You can deliver more fuel by raising the system pressure by adding shims to the regulator in the FD. You can deliver more fuel by adjusting the mixture screw, though you have to be careful not to make it so rich at idle too that it won't idle adequately.
You can lower the warm control pressure in the WUR by raising the big plug so the FD presents less pressure countering the rise of the fuel plunger to the slots.
The six differential pressure diaphragms can be adjusted with their adjustment screws, though usually one only adjusts them so each fuel injector discharges at the same rate as its brothers and sisters.
I have trouble envisioning anything you could do directly to the FD, like making some passages larger or something, which would be at all practical.
Old 06-26-2017, 05:52 PM
My tuner already tried to "play" with those parameters
but if go on the full charge direction
after idle and warm up is not good any more
he works on Kjet since many years so the only option available in my case is to increase the full charge fuel delivery
for information they push until 5.2 bars but no significative improvement
my head is rebuild this week
next week I expect first results
we will see
Old 06-27-2017, 10:23 AM
Non User
infraredcalvin's Avatar
No personal experience, but these guys are mentioned in the forum often for mods:
CIS Flowtech - Rebuilding Bosch Fuel Distributors & Warm-Up Regulators
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 06-28-2017, 06:36 AM
The only good thing about CIS fuel heads is they fit in your hand so you can see how far you can throw one of the miserable things...
yeah, I've hated bosch CIS since the first time I saw it and had to waste time and money buying special tools and screwing with it over 30 years ago in BMW's... and they only get worse.
Old 06-28-2017, 10:36 AM
the guy did not upgrade the piston
he check the distributor
good state
not leaking
no rust inside
my distributor can be set up
so initial result
105 ml per injector
final result 130ml per injector
my tuner will test it and we will see if it's enough for the lambda or if we need to do a hardware mod to increase de quantity
we will see next week
Old 06-29-2017, 09:43 AM
Your guy doesn't have a machine set up to enlarge the tiny fuel plenum chamber around the metering slits in the control plunger cylinder or the 6 orifices above the diaphragm or the experience that goes with figuring that out.
Larry Fletcher of CIS Flowtech does so just send it to him or enjoy chasing your tail in endless circles and paying your guys meal ticket till your broke and dizzy.
Old 06-30-2017, 07:20 AM
Sorry you are wrong
He was just able to achieve the increase the tuner asked for without modifying the cylinder
I pay 100 dollar for the full set up plus wur
And calibration
If it s not enough
He can do the modification
Again
Everything is checked with values and afr
So it s definitly not the amateur world
Old 06-30-2017, 01:44 PM
