-   -   Exterior block cleaning (http://forums.pelicanparts.com/911-engine-rebuilding-forum/963957-exterior-block-cleaning.html)
outsider347 07-27-2017 06:05 AM
Tks Steve
The galley plugs are the press in plugs that look like freeze plugs?
Do you purchase those locally?
Tks for your responses
ed
boosted79 07-27-2017 06:26 AM
Ed - I have a lathe so I make the plugs from alu round stock. I guess steel core plugs would work if they are the right size, do a search on here to see what people use.
Dpmulvan 07-27-2017 06:28 AM
Originally Posted by outsider347 (Post 9677961)
Tks Steve
ed
You can buy them from our host
boosted79 07-27-2017 07:20 AM
Another thing I like to do, use extra long exhaust studs and machine stainless spacers for under the nuts. This does two things, it makes the nuts easier to get to (Ronnie, your response goes here) and if you ever want to remove them and one doesn't want to come off you can cut it off and still have enough stud left for a new nut. I use the copper plated prevailing torque nuts and never seize.
http://forums.pelicanparts.com/uploa...1501164982.jpg
outsider347 07-27-2017 08:42 AM
I have a lathe as well...do you happen to have the diemensions
boosted79 07-27-2017 10:35 AM
I just measured the ones I knocked out and added a couple thou, don't know exact dimension. Once in I roughed up the plug and case and applied epoxy. There is one you have to pay attention to the depth, too deep and it blocks an oil drilling, forgot which one though, it's on here somewhere.
