Exterior block cleaning
Soon to start my re assembly
Case halves have been well degreased several times, then power washed several times as well.
I'd like to get the stain & oxidation removed from the outside. A friend suggested a weak acid/navel jelly product that "works" the aluminum without a lot of scrubbing
any suggestion/thoughts?
tks
Old 07-21-2017, 12:00 PM
Google Vapor Blasting
Old 07-21-2017, 02:35 PM
No one close by, and I really don't want to ship
Old 07-21-2017, 05:05 PM
Under the radar
Trackrash's Avatar
I used Prep and Prime on my case. It helped, but it required a lot of brush work to get it really clean. Don't leave it on or it will darken the aluminum. In my case, I really didn't want it to look too shiny. I wanted it to be clean and new looking, not polished.
If you really want your case to shine, put it in a vibratory polisher.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-21-2017, 07:31 PM
soda blast followed by cerakote matte clear
Old 07-22-2017, 04:44 AM
Your in Orchard Park there's plenty of places around Buffalo. + 1 Soda blast or Dry ice Blast then cerakote. If you have a good compressor you can use a harbor freight blaster with a few mods the most important being replacement of ball valve with proper media valve.
Old 07-22-2017, 04:59 AM
Under the radar
Trackrash's Avatar
I wanted clean, not polished.
Gordon
Old 07-22-2017, 07:36 AM
Clean,
Safety Kleen, degreaser, pressure washer, degreaser, pressure washer.
Gets the caked grease off.
Old 07-22-2017, 09:59 AM
I do have a good compressor/pressure blast setup.
Is the only pressure pot mod to swap out the bottom ball valve?
tks
ed
Old 07-23-2017, 05:35 AM
Ken911's Avatar
ok so is cerakote just a paint that you can DIY? or do you have to take it someplace to have it done?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-23-2017, 04:38 PM
Yes you can DIY. But make sure to mask everything so none gets on the inside of the cases, stud holes, etc. I use a small touch up gun to spray it. And you need a good organic mask, I have never smelled any paint like this, just taking a little whiff from the can will almost knock you over. It needs to be sprayed on in thin coats or you'll get runs. It's like 60-70 for a pint but that will be plenty. It's the best there is for clearcoating metals. I use the matte so it doesn't look glossy.
https://www.clearcoating.com/
Old 07-23-2017, 06:03 PM
Ken911's Avatar
Did you use the MC-157 or the 161?
2019 Silverado 6.2L
Old 07-24-2017, 05:47 AM
tks
ed
Yes ball valves are not ideal for blasting material, you can make a simple valve using a piece of rubber hose and a clamp, or pay a $100 for a media valve. I also added a piece of pipe with several holes drilled in it that attaches to the tank fitting and goes up inside the tank. Cheap blasters get a bad rep, mainly because of the lack of a proper media valve and lack of decent dry air.
Old 07-24-2017, 06:03 AM
I used the 161, the 157 is thinner which makes it easier to run.
Old 07-24-2017, 10:19 AM
Ultrasonically cleaned:
How it looked before cleaning:
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 07-24-2017, 01:30 PM
[QUOTE=boosted79;9671981]soda blast followed by cerakote matte clear
[/SB
Did you use the SB from china freight?
Old 07-25-2017, 05:08 AM
what is sb?
if it's sand blaster, yes. The siphon blaster cabinet, not the pressure pot that is used outside. But a better gun from TP tools and I have a cyclone separator going into a shop vac that I put outside of the shop. I have a big comp. system. 17 scfm or so and both water and air cooled aftercoolers to drop out as much moisture as possible.
Old 07-25-2017, 09:27 AM
sb=
Soda Blaster
Old 07-26-2017, 08:19 PM
I run soda in the cabinet after I vacuum it AND hose it out. I then immerse the part in water after the soda and then hose it off. I remove all galley plugs before degreasing and run gun brushes thru the galleys along with brake cleaner. I run gun brushes thru after the soda also and spray water thru all the galleys. It's a lot of work but the finished product with the cerakote is really nice.
when I'm blasting a case I also put rubber stoppers in the galley holes just to try to keep the soda out.
Old 07-27-2017, 04:52 AM
Old 07-27-2017, 05:36 AM
