Under the radar
I bent, yea bent, a JE circlip trying to install it without a tool. I had two go flying at warp speed, with one still MIA. None were permanently deformed or sent flying using my home made tool.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-26-2017 at 08:21 PM.. |
Clip tool
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Irrationally exuberant
[1] resizing the case is a process where a little bit of material is removed from each side of the case and then the crank and intermediate shaft bores are recut. This allow you to use standard bearings instead of oversize bearings which cost 3X what standard bearings cost.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
