Any risk to glass beading?
Getting ready to bead blast my heads...
Tried the GUNK bucket carb cleaner (Berryman equivilant), and Methylene Chloride (paint stripper)... so far, super slow to do anything...
I have a bead blast/sand blast cabinet...
Anything to NOT blast?
I know that when I do powdercoating, bead blasting does seem to deposit some debris into soft metals, which shows up under the powdercoat...
When you bead blast a head, do you avoid the mating surface to the cylinder? Assuming you don't want to machine it, as it is fine...
Do you avoid the valve seat, or valve sealing area?
Avoid the valve guides?
My heads/valves seem to be in spec, just want to clean off the carbon...
Old 08-30-2017, 05:05 AM
Chain fence eating turbo
Yes, avoid any sealing surfaces as the machined/lapped finish will be compromised.
Old 08-30-2017, 06:10 AM
You can even sand blast heads if you need to. There are no internal passages obviously so do whatever it takes to clean them, noting what Tippy said about hitting sealing surfaces. I use duct tape on the parts I don't want to blast.
Old 08-30-2017, 08:10 AM
Under the radar
Trackrash's Avatar
Soak the combustion chambers with brake fluid. It will dissolve the carbon. Then wash with gasoline followed by a good degreaser. If you want them shinyer, follow that with phosphoric acid (prep n prime) and a brass brush. It used to be we could get chemicals that would clean oil off of parts. Now they have to be environmentally friendly. H*ll, I can't get carb cleaner to clean the oil off my floor anymore. I digress.
Most shops bead blast since it is much faster. You need to make sure to use new beads of the correct grit.
A machinist friend of mine showed me some heads someone had bead blasted and the cylinder seating surfaces were no longer smooth. They had used old beads, which were broken with sharp edges.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-30-2017, 09:21 AM
Sounds like I may revert to soda blasting then... Never tried that though...
I have 2 vlaves dipped in a jar of paint remover right now. Will see what they look like when I get home.
Paint remover seemed to work much better than carb cleaner in a bucket...
Have never tried brake fluid...
Some on here have also recommended heating in an oven and using oven-off...
Old 08-30-2017, 09:51 AM
Don't use gasoline. You can die.
Old 08-30-2017, 10:56 AM
Under the radar
Trackrash's Avatar
No question gasoline is toxic and flammable.
What can someone, who doesn't have a hazmat permit, buy that will clean engine parts?
Gordon
Old 08-30-2017, 11:16 AM
