Jase77's Avatar
EPS 11 Blade Alternator Fan
Hi Pelicans,
I need to replace the 5 for an 11 blade Alternator fan on my 77S. I cannot justify the 750€ price tag on the early version (circa 74/75), so I have found a possible alternative.
It's by a company called EPS. I tried to include the link but no luck.
It certainly looks good but I would rather hear it from the horses mouth. Any of you had any experience with this fan?
Many thanks,
Jason
1994 968CS
1977 911S
1969 MGB GT
1958 Norton Dominator
Old 10-13-2017, 11:26 AM
Tom '74 911's Avatar
I recently acquired one to replace the stock 5-blade fan on a 2.7L rebuild I am doing. I must say, it looks great. It'll likely be the shiniest, newest looking part on the engine when it's done... (engine is still in pieces so I haven't run it w/the fan yet)...
As far as I can tell, the EPS fan is a good option as OEM new ones are big $$ and good used ones are hard to come by and still likely $$...
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 10-13-2017, 12:29 PM
E-85 sippin drunk
turbobrat930's Avatar
A friend of mine is going to be posting a new fan and fan shroud for sale in the next day or so... keep your eyes on the 911 classified forum...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 10-13-2017, 12:33 PM
A 77s used the later ratio fan with the circle of small holes on the pulley halfs. 78/79 is too small but 80 to 89 will work. I think on a 77 it will require the 725 fan belt because of the larger crank pulley.
Bruce
Old 10-13-2017, 04:37 PM
Jase77's Avatar
Thanks for your feedback Gents,
From what I have read so far the pulley half should be 3.25" diameter for the later spec fans (80-89) Does this sound correct to you ?
My old pulley half is that diameter but it is the type with the extra belt for the additional air pump, which I have removed.
Cheers,
Jason
1994 968CS
1977 911S
1969 MGB GT
Old 10-13-2017, 11:39 PM
