EPS 11 Blade Alternator Fan
Hi Pelicans,
I need to replace the 5 for an 11 blade Alternator fan on my 77S. I cannot justify the 750€ price tag on the early version (circa 74/75), so I have found a possible alternative. It's by a company called EPS. I tried to include the link but no luck. ![]() It certainly looks good but I would rather hear it from the horses mouth. Any of you had any experience with this fan? Many thanks, Jason
1994 968CS 1977 911S 1969 MGB GT 1958 Norton Dominator |
I recently acquired one to replace the stock 5-blade fan on a 2.7L rebuild I am doing. I must say, it looks great. It'll likely be the shiniest, newest looking part on the engine when it's done... (engine is still in pieces so I haven't run it w/the fan yet)...
As far as I can tell, the EPS fan is a good option as OEM new ones are big $$ and good used ones are hard to come by and still likely $$... Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
E-85 sippin drunk
A friend of mine is going to be posting a new fan and fan shroud for sale in the next day or so... keep your eyes on the 911 classified forum...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
A 77s used the later ratio fan with the circle of small holes on the pulley halfs. 78/79 is too small but 80 to 89 will work. I think on a 77 it will require the 725 fan belt because of the larger crank pulley.
Bruce |
Thanks for your feedback Gents,
From what I have read so far the pulley half should be 3.25" diameter for the later spec fans (80-89) Does this sound correct to you ? My old pulley half is that diameter but it is the type with the extra belt for the additional air pump, which I have removed. Cheers, Jason
