Cam tower & rebuild questions
After disassembly of engine and checking #s ...my case is 9011011023R as for a 71 2.2T but the Cam tower is 9011051111R which seems to be from a 76 .
Is this correct and is there any issue with mating these.
Also have decided to go for slightly over 2.5 rebuild using 87.5 Nickies cylinders and matching CP pistons at 9.5/1
Are there any issues with the 87.5 in the 3R case?
Weber IDA's and DC3 cams also a 70.4 crank & rods
Comments are appreciated
Frank
Gold71
Old 09-20-2017, 05:30 AM
No issues, cam towers are all the same grouped into 3 bearing towers and 4 bearing towers. As long as your cam towers match the number of bearings on your cam (the large, perfectly round lobes that run the circumference of the cam) your fine.
Old 09-20-2017, 08:50 AM
Can one lose significant oil pressure somewhere from a cam tower? You never hear folks talk about that...
Old 09-20-2017, 11:31 AM
Thanks ......any issue with the 87.5 for the 3R case.
I know there has been general comments to 86mm as limit?
Frank
Gold71
Old 09-20-2017, 03:52 PM
