-   -   3D model/render work on the 2.2T motor I'm building (http://forums.pelicanparts.com/911-engine-rebuilding-forum/971257-3d-model-render-work-2-2t-motor-im-building.html)
'76 911S 3.0 10-11-2017 09:33 AM
Wow...really nice work!
Optimusglen 10-26-2017 04:03 PM
More progress today!
http://c1.staticflickr.com/5/4514/37...dfb40ae9_h.jpg
Catorce 10-26-2017 09:10 PM
Fantastic!
chris_seven 10-27-2017 02:22 AM
https://www.cgstudio.com/3d-model/porsche-911-engine-10822
This has been around for a while but doesn't look as good
Optimusglen 10-27-2017 06:46 AM
Yes, I saw that. It lacked the detail I wanted (specifically, none of the guts are there) and decided to make my own.
Tippy 10-27-2017 07:30 AM
Originally Posted by Optimusglen (Post 9758696)
I've found that if you originally learned on Solidworks, or are pretty green, you'll almost always favor Solidworks. I learned on Pro/E, and have been using every new iteration of the software for close to 20 years. So it's no surprise that I'm a Creo fanboy. Haha.
Catorce, thank you!!
I actually have found weak links in SW's that ACAD Inventor does better and Mechanical.
Guess I'm getting more familiar with it all. They all use the same base coding AFAIK. Mostly GUI differences from understanding?
Optimusglen 10-27-2017 08:13 AM
I'm not familiar with anything from a coding standpoint, I'm completely oblivious haha.
Here's a quick edit you guys might like. I don't have the valves/springs/retainers etc in there yet, but the ports are there.
http://c1.staticflickr.com/5/4456/24...9ca876b2_b.jpg
link to a high res if anyone wants a new desktop background
http://c1.staticflickr.com/5/4456/24116722878_fc87775dc3_o.jpg
Tippy 10-27-2017 08:25 AM
Awesome!!!!
Optimusglen 10-30-2017 01:27 PM
A few additions. Worked on getting the components done for the head assembly.
http://c1.staticflickr.com/5/4493/38...8f890cc4_b.jpg
Then moved onto the intakes.
http://c1.staticflickr.com/5/4444/38...015b9545_b.jpg
http://c1.staticflickr.com/5/4477/24...626df4ee_b.jpg
horizontallyopp 10-30-2017 02:45 PM
I feel like you are working your way towards a full VR model to enable us to practice our engine rebuilding skills without an actual engine! These renders are just awesome.
Tom Elder 11-04-2017 07:22 AM
Hi, Just wanted to join the fan-wagon and say I really enjoy your images and skill, and appreciate the time it takes to measure everything and do this work.
I am old enough to have spent 15 years on the pencil drawing board, doing technical drawings and I find the latest scan, cad, rendering technology amazing, compared to the old school methods of a few decades ago!
Keep the images coming!!! Cheers, Tom
Optimusglen 11-08-2017 03:49 PM
Thanks guys!
Had a chance to start the long journey that is the Zenith carbs, roughed in, needing so many features.
http://c1.staticflickr.com/5/4571/24...4965f08b_h.jpg
Also added the fan pulley.
Optimusglen 11-11-2017 02:47 PM
More!
http://c1.staticflickr.com/5/4537/38...c7afd482_h.jpg
Catorce 11-11-2017 03:42 PM
Amazing
Spenny_b 11-12-2017 02:49 PM
I think you'd give Instagram a melt-down if you were to start posting these renderings on there! Seriously impressive. Need these as prints in my workshop. And man-cave. And house. (no, there's no Mrs Spenny_b thankfully :D )
Optimusglen 11-13-2017 04:22 AM
Thank you! They are already on Instagram, I just don't have a ton of followers.
www.instagram.com/autoillustrated
Tippy 11-13-2017 06:10 AM
Simply gorgeous.
dkirk 11-14-2017 09:02 AM
Incredible! Thank you for your time and dedication to this wonderful effort...much appreciated!
Optimusglen 11-24-2017 08:25 AM
I got some time to start hashing out the Zenith carbs, one side coming along nicely, the other side not started yet.
http://c1.staticflickr.com/5/4572/26...c5827f0c_h.jpg
http://c1.staticflickr.com/5/4558/26...9689ff82_h.jpg
Optimusglen 11-24-2017 09:22 AM
And an all clay rendered version.
http://c1.staticflickr.com/5/4551/37...aaa688e4_h.jpg
Tippy 11-24-2017 10:12 AM
If I ever had some free time at work, I could contribute to the "cause".
Is there anything you need modeled?
rwest 11-24-2017 05:28 PM
Wow, amazing detail, great work.
Optimusglen 12-02-2017 07:22 AM
This is certainly the most challenging part so far, took a dive into the first case half.
Long long way to go, but the foundation is there.
http://c1.staticflickr.com/5/4557/24...647f1b0c_b.jpg
Catorce 12-02-2017 09:10 AM
That's a great start!
Optimusglen 12-04-2017 09:35 AM
More on the carbs, been really cool to get up close and personal with all of the stuff that you usually just clean and assemble.
http://c1.staticflickr.com/5/4530/37...f91979c9_h.jpg
http://c1.staticflickr.com/5/4576/37...92b20367_h.jpg
http://c1.staticflickr.com/5/4579/24...b1c6d31f_h.jpg
I don't have modeled screw threads on most of the stuff that uses threads, mostly because it takes so much more time to create/export/render. Once the model is done I'll be going back and added the threads as a bump map on the surfaces that need it. For now you get smooth cylinders going into smooth cylinders.
lvporschepilot 12-04-2017 09:40 AM
Great stuff, enjoying this. Will this model be able to simulate combustion and heat sources?
Optimusglen 12-08-2017 09:52 AM
It is a parametric 3D model, so parts could be imported into other software systems to simulate that stuff. I have no access to such a software though. And since these aren't 100% accurate down to the 10th or 100th of a millimeter I don't think running these models in such a software setup would gain anyone any usable knowledge.
Making a little progress on the first case half. Guessing maybe a little under halfway there. then I get to do it all over again with the other half...
http://c1.staticflickr.com/5/4569/38...4275c409_b.jpg
Tippy 12-08-2017 10:16 AM
I wished I was that good in CAD! I'd love to see the basic foundation on how you started
Optimusglen 12-10-2017 08:57 AM
More work on the carbs, floats are in as well as the lower portion of the airbox. Still some details to add to the airbox
http://c1.staticflickr.com/5/4541/38...2b45bfe3_b.jpg
From above as clay.
http://c1.staticflickr.com/5/4725/38...cbd8fef9_b.jpg
and from the side as clay
https://c1.staticflickr.com/5/4692/3...1e9f0147_b.jpg
Optimusglen 12-11-2017 03:47 PM
Added more airbox details, I'll be revisiting the first case half and adding details in a few days.
http://c1.staticflickr.com/5/4647/25...02f72abd_b.jpg
'76 911S 3.0 12-11-2017 03:48 PM
Unreal
Trackrash 12-11-2017 05:41 PM
Masterful work. Simply amazing.
Optimusglen 12-11-2017 07:15 PM
Thanks guys! Had a bit more time this evening and started on some other bits.
http://c1.staticflickr.com/5/4578/38...f606ef8c_h.jpg
Catorce 12-12-2017 09:13 AM
WOW, so awesome, I love the clay!!!!
Optimusglen 12-16-2017 07:06 AM
In my classic for of stirring multiple pots at once, here's a start on the engine air shroud. No rendered image this time, the baby is about to get up so I need to go make a bottle...
http://c1.staticflickr.com/5/4739/39...dfa5347d_b.jpg
I should note, the transmission is just a placeholder for now. I found this model online and popped it in, supposedly a 930 trans? At any rate, I'll be doing my own at some point, but want to finish the engine first.
Optimusglen 12-17-2017 07:02 PM
http://c1.staticflickr.com/5/4601/38...3887bfae_b.jpg
More
Eric at Pelican Parts 12-18-2017 10:07 AM
Wow, this is amazing, the attention to detail is staggering! I could definitely see 3D printing these and leaving them around the house as art too.
Optimusglen 12-18-2017 11:00 AM
Thank you! Here's the most recent. Little bits of work on it at a time, it takes patience but eventually it'll be complete.
http://c1.staticflickr.com/5/4681/38...92f8eef9_h.jpg
Optimusglen 12-19-2017 06:49 AM
I needed a new desktop background...
http://c1.staticflickr.com/5/4593/25...872053e0_h.jpg
Edoyle 12-24-2017 05:14 AM
Amazing work. I encourage you to make some sort of art with the model once completed (Poster, 3D print..).
