Your rendering work is amazing. I particularly like the exploded rocker arm picture- beauty in simplicity.
Rutager West 1977 911S Targa Chocolate Brown |
lake wales fla
Truly magnificent art
All i can say is wow, while your canvas and brush are a computer screen and micrometers you truly are an artist
Michelangelo reborn........
Glen,
I get goose bumps looking at your computer generated images. You are a genius in my book. Please continue making more of your master pieces. Thanks for sharing. Tony |
In a previous life I used UG, later named NX. Your modeling is beyond impressive. As mentioned people probably would buy posters/etc.
Sold: 1989 3.2 coupe, 112k miles |
Fantastic work - thanks for sharing!
Jason
'79 911SC Targa |
thanks guys! I've started trying out some animation within the rendering software I use. Just teaching myself so it's all very basic, but thought you guys might enjoy it.
Instagram = glen.cordle for my Porsche artwork and 3D models. |
What rendering package do you use? vray, keyshot?
Answered in the first post, Keyshot.
Some more parts added.
Gorgeous! Looking at it, I felt something was wrong and thought - 'OMG, he's made a mistake with the exhaust!'. I then remembered this engine goes into a 914, not a 911!
Michel 1970 911T |
Haha, yeah. I modeled the 914 exhaust first because I had a real set to build from. I do plan on doing a 911 orientation but for that I'll need to work off photos I find online.
So it's looking like the case for my real 911/07 needs to be sent to Ollies, bummer but I suppose it was to be expected.
I've made a few additions to the 3D model, still so many details I need to tackle, and I haven't even started the throttle linkages. ![]() If anyone is interested in an art print, I do have a few views up at society6.com/autoillustrated
Fantastic!! You never disappoint with these updates!
The animation with the rendering software is really cool. Do you have plans to animate the motor so it runs?
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
Layouts for the heads
So cool! A beautiful thing of beauty!
Michel 1970 911T |
Chain fence eating turbo
Can I ask how big the file is now in data and what kind of hardware are you running to be able make such a monster assembly?
My laptop fully spec'd from HP can barely run fixtures I've put together and sometimes takes hours to convert files from customers.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
After I create the models I export as step files. A step file is a universal true geometry format that can generally be opened by any model software, but it's a "dumb" model in that if I want to change a hole size from 10mm to 11mm for instance, I can't just click on that feature and change the value from 10 to 11 like I could in the native file. The bright side is that the step file is a bit more compressed than the native file, the engine/trans assembly is about 200mb. When I import the step file into my rendering software, the import process converts the smooth round surfaces into triangles, this is called tesselation. I choose how much tesselation on import, the highest value of 1 breaks the surfaces into billions of triangles and thus extremely large files. For my latest image that one was brought in with a tesselation value of 0.15 and contains 30,500,000ish triangles with a file size of about 650mb which is manageable. Here's a shot of a valve cover showing the individual triangles. ![]() The software does this because it needs to calculate exactly how much light is reflecting where to make true photo-realistic images. Higher tessellation values make for more accurate reflections because it's breaking the surfaces up into smaller facets and calculating each and every one for color and light. I have some files that are multiple gb, but much of that is because I brought everything in with a much higher tessellation value earlier on in my history. And applying labels and decals brings the file size up a lot too. This Martini 914 model with my engine model installed is 5.5 gigs. If I brought this up and updated the tessellation value I could likely bring this down quite a bit though. ![]()
Throttle linkage done finally.
