Help identifying engine, where to look for numbers?
I have been cleaning up my late dads storage and found this engine the other day. Quick glance I didn’t see any numbers stamped, so not sure where to look.
Any insight on what year/model it is. |
Search is you answer....the number you are looking for are here look..where is the finger and also where is the circle
Ivan |
Unless it is a 914/6 motor.
John Thompson Eugene, Oregon |
Hi to Oregon..maybe you could show him where the 914/6 number would be ..or??
Ivan |
914/6 number s located by the thermostat and case breather.
Bruce |
so, what gives it away as a 911 engine is the oil pressure switch partly covered.the 914/6 has an oil press sending unit in its place.So it is a 911 ..which one, to be continued
Ivan |
Ok it says 6196145 on the block.
and the number where the circle is? something like 901/16....?the other number points to 1969 911T
ivan Last edited by proporsche; 10-07-2017 at 09:24 AM.. |
so here you have it it is 1969 911T...
Ivan |
