Is 4 to 5 thou too much main bearing clearance
Hi has anyone ran 4 to 5 thou main bearing to crank clearance?
3.4 std oil pump,10.5 :1 com 7500 rpm?
Old 05-27-2014, 04:10 AM
Air Medal or two
afterburn 549's Avatar
only in drag machines might you get away with it for a little bit. JMO
Why so loose?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-27-2014, 09:32 AM
otto_kretschmer's Avatar
my Haynes manual calls out .0003 to .0028 for bearings 1-7
Old 05-27-2014, 09:41 AM
Air Medal or two
AFAIK typical is 1.5 all the way around ( oil clearance, most engines)
Old 05-27-2014, 09:49 AM
Mine just came in around 0.0348mm or .00137in... Stock SC crank with 100k on her.
Old 05-27-2014, 11:33 AM
Air Medal or two
some people make a mistake using plasti guage
When crank is laying dwn against main bearings on one side so you get double the gap on the measured side.
Old 05-27-2014, 11:37 AM
Hi I have been using plasti gauge and are getting around 0.004 "
Crank is in spec, case is in spec have tried 3 different bearings still over 0.003"
Where to from here, Grind crank, line bore,?
Does any one know how much thicker genuine Porsche bearing shells are over Glyco?
Old 05-27-2014, 04:25 PM
Air Medal or two
Mag case ?
Old 05-27-2014, 04:30 PM
3.2 alloy case
Old 05-27-2014, 04:32 PM
If i grind the crank , do i really need to re case harden it?
Old 05-27-2014, 04:33 PM
Air Medal or two
Leave it to shop that does P.cranks.
I do not think so as far as re nitride or something
Check on bearings B4 you go too far...some have become real expensive and not available .
Old 05-27-2014, 04:39 PM
How does grinding the crank reduce bearing clearance?
Gary Kozun
83 911SC Cabriolet
Old 05-27-2014, 09:51 PM
You reduce clearance by running oversize bearings. Just to be clear, the bearings fit a standard size bore in the case, but have more material so they fit a crank journal that is smaller than standard.
Old 05-27-2014, 11:21 PM
Understood. But no where was he stating using oversized bearings.
The statement was that he had 4 to 5 K clearance at present and wanted to know if line boring and crank grinding was necessary. Yes, it would be if going to oversize bearings but not if you were trying to reduce clearances.
I do see there is another thread where he asks about hardening a crank after grinding and using oversized bearings. So in that context take my earlier statement as non meaningful.
Gary Kozun
83 911SC Cabriolet
Old 05-27-2014, 11:31 PM
Air Medal or two
From things i think I know.
Is your crank journals "egg shapped"??
If not your measuring must be wrong.
I would have a experienced person do it .
Its hard to remove that much material in normal wear .
If it is under sized you will to have the crank machined dwn to the next size and install bearing to match.
Old 05-28-2014, 02:46 AM
Have you measured the bearings after they have been torqued in the case without the crank? Did you use a bore gauge that was zeroed with the same micrometer that you made the crank measurements with? Both of these are critical to get accurate bearing clearances.
Here is how it's done:
https://www.youtube.com/watch?v=7VayaKK2mJI
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-28-2014, 05:35 AM
Using plastigauge
I've been wondering about this...
So if you use plastigauge, and get 4 thou as the clearance measured, does that mean your bearing clearance is actual 2 thou?
Old 08-23-2017, 06:44 PM
Under the radar
Trackrash's Avatar
I'm not sure what Afterburn was thinking. Not true.
Did you properly torque the case through bolts? What motor are you working on?
Here is my crank's clearance.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-23-2017, 08:18 PM
Hi Gordon... working on a 3.0SC...
I'm not an expert and have just started learning to use micrometers and bore gauges..
So far I have measured my crank to be perfectly in spec. Using the bore gauge, I am getting a clearance of 0.08mm which equates to 3 thou... 0.003 inches.
Using plastigauge, I am getting 4 thou.. 0.004 inches..
The measurements I am getting on the bore gauge are repeatable.. but I am a novice. So not sure if I am doing it wrong every time!
Old 08-24-2017, 04:38 AM
Chain fence eating turbo
Don't think you'd have any oil pressure at those clearances!
Old 08-24-2017, 05:17 AM
