2.4 sump screen options
I have both the old original sump screen and the one for an sc.. Which should I use or does it even matter?
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
screen
The one on the left is the latest update and the preffered style, it improves the scavenging like the 3.2 and later style pumps have
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Thank you that is what I thought but wanted confirmation. My pump has been improved by supertec so wanted to make sure the screen is preferred.
I think if your case has the oil bypass and if you are using a 4 rib pump or later, the venturi style sump screen (on the left) is the right one to use,
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Yes oil bypass has been done and here is the picture of the pump after upgrade from supertec.
